Replacing stock motive gears to new? - Mustang Evolution
Old 08-11-2008, 04:12 PM   #1
I am thinking about taking out my stock 3.73 (pretty sure) to new 4.10. Anyone know how simple this is and what exactly will i be needing as far as tools go or lifts? Im pretty much in the dark here. I heard about how much they can really wake up your GT but before I buy them I wanted to see if it was going to be VERY difficult for me to do. Your thoughts??
Colton R. Pepper
1999 Mustang GT
NavyGT99 is offline   Reply With Quote
Old 08-11-2008, 04:16 PM   #2
Re: Replacing stock motive gears to new?
You have 3.27's stock....and the 4.10's will wake your car up a lot. You will need to correct your speedo with a tuner or else the speedometer will not read right and neither with your odometer.
How hard is it, well, it isn't that it is hard, it is a precise thing. You have to make sure the backlash and everything is just so. I've never done a gear swap though, so I can't give you a lot of details about it.
You should be able to find a shop that would install them for $200-300 or so...
Old 08-11-2008, 04:22 PM   #3
sweet. Ya i wasnt sure about the ratio. Google lied I guess haha. Do you know if by swapping out the stock gear with better ones could at all screw up the rear end if done correctly. For example, is there anything else I should look into getting ontop of the new gears.
Colton R. Pepper
1999 Mustang GT
Old 08-11-2008, 04:24 PM   #4
1234's Avatar
New rearend seals. More specificly. The axle seals.
Old 08-11-2008, 05:17 PM   #5
What do you think it would do to my gas as far as the MPG?
Colton R. Pepper
1999 Mustang GT
Old 08-11-2008, 05:29 PM   #6
1234's Avatar
If im not mistaken hurt it a bit on the highway maybe 2-3 mpg and help it a bit in city driving maybe 2-3 mpg
Old 08-11-2008, 08:48 PM   #7
you dont have the tools to do it, have them installed somewhere, you axle seals are fine if they arent leaking but always go back with a new pinion bearing and seal.
SimplyOrange is offline   Reply With Quote
Old 08-12-2008, 07:16 AM   #8
do not do a gear install yourself, leave it to a pro... its not hard its just hard to get them right~ most shops just toss them in as well... take it to a shop that knows what they are doing and have a warranty in writing to cover gear whine and premature wear due to bad install.
NEED HELP WITH GEARS!! Motive 4.10 gears? Cant find ford racing? Camaro Eater Pre-2005 V6 Mustang 4 06-23-2010 10:57 AM
replacing stock system... want input Taywi Mustang Audio & Video 31 12-22-2007 10:44 PM
Motive Gears Ghostbuster 1996-2004 Mustang GT 10 04-29-2005 05:43 AM
Replacing Stock seats from a 94-98 with leather 99+ Black95GT Mustang Audio & Video 3 07-29-2003 09:01 AM
05:58 AM
