Water Leaking on Right side - Mustang Evolution
Old 02-13-2018, 11:59 AM   #1
I put this on the 2005 to 2009 forum and just got one solution to the problem which I'd already done. I found my carpet soaked on the driver's side. A couple of years ago I had this happen to the passenger side and I was told to pull the rubber plug from the drain hole beneath the windshield. I did this. Last fall, it happened on the driver's side so I pulled the rubber plug from the drain hole on that side. (should have done this at the same time as the other.); Both times, this rubber plug was completely plugged up. However, now I am getting a soaked floor on the driver's side again. I checked the drain hole, It is clear, at least from the bottom. All I did was reach beneath to see if the hole was clear and it was. I can't see water leaking down anywhere and I just had my windshield replaced last summer. Anyone have any other ideas? Is there other ways water might be getting in that I can look for before putting it in a shop?
Trickle is offline   Reply With Quote
Old 02-14-2018, 01:26 PM   #2
thought there was another seal under hood towards windshield? I removed both plugs last year after passenger side got soaked, stupid design.
Heinz
06 GT, auto, 65K
hfca is offline   Reply With Quote
Water Leaking on Right side Trickle 2005-2010 Mustang GT 5 08-15-2017 02:10 PM
Water leaking in under passenger side dash 06, yes I read TSB! hfca 2005-2010 Mustang GT 5 02-17-2017 03:47 PM
Leaking water on passenger side! Cam Capollo 2005-2010 Mustang GT 11 03-27-2014 11:23 AM
Water leaking on passenger side 06gttwofast4u 2005-2010 Mustang GT 6 06-05-2013 03:43 AM
Water leaking in under passenger side dash dudeitsdylan 2005-2010 V6 Mustang 15 07-06-2012 11:30 AM
08:01 PM
