What is the fix for this DTC code? - Mustang Evolution
Old 08-19-2008, 11:28 AM   #1
P1150 - Lack of Upstream Heated Oxygen Sensor Switch - Adaptive Fuel Limit - Bank No. 2
Obviously it is an O2 issue, but what does it mean and what is the fix?
Old 08-19-2008, 12:43 PM   #2
ChrissyStang02's Avatar
Region: Iowa
Send a message via MSN to ChrissyStang02 Send a message via Yahoo to ChrissyStang02
Re: What is the fix for this DTC code?
Make that code # P1151. Sorry guys!
My baby...
No, it's not my boyfriend's car and no, you can not drive it.
2002 Mineral Gray Mustang GT ~Dominic~
MagnaFlow Catback Exhaust, CAI, Mach 1 Grille Delete and much more to come. ***Sold. New 5.0 GT coming soon!!!
ChrissyStang02 is offline   Reply With Quote
Old 08-19-2008, 02:35 PM   #3
MonteCitan's Avatar
That means the sensor isn't seeing a change in oxygen levels, its pegged either rich or lean and is not switching - You really need to get access to a scan tool and monitor several things, MAF input, TPS, Short and long term fuel trims, fuel pressure, etc, it could be as simple as the 02 sensor itself..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 08-19-2008, 02:40 PM   #4
I'm in BR...the car in question is in Ottumwa, IA....I'm pretty limited unfortunately.
I had her clear the code and see if it would come back right away. If it does, I told her to change out her 02 sensor and see what happens then. Unfortunately, it's a bit of a drive for me to head up there and datalog stuff for her...and she doesn't have a tuner, so that will really limit things.
Old 08-20-2008, 06:30 AM   #5
its an o2 sensor, p1151 is bank 1 im pretty sure that is the passenger front o2 sensor and it is bad...id change both while i was doing it.
i can check when i get back to the shop, but im not sure when i will be there again, im on turnaround right now
SimplyOrange is offline   Reply With Quote
DTC Codes? oldtexasdog 2005-2010 Mustang GT 2 07-07-2010 08:43 AM
Code P1443 How to fix it? Neptuno Pre-2005 V6 Mustang 2 09-03-2004 08:28 PM
Nobody can fix...please help! BluStang6 Pre-2005 V6 Mustang 2 01-05-2004 03:11 PM
04:52 PM
