Amp Rack - Mustang Evolution
Old 10-30-2008, 07:58 AM   #1
at7311's Avatar
Send a message via AIM to at7311
Amp Rack
The amp rack (for the back speakers) in the trunk are becoming loose and every time I hit a bump it rattles big time. I have tried getting in the trunk with a ratchet to try to tighten the bolts. They just spun and didn't seem to ever tighten. Any one have this problem and know how to fix it? What bolt sizes are they? etc.. any advice would be great. Thanks.
at7311 is offline   Reply With Quote
Old 10-30-2008, 08:05 AM   #2
braumab's Avatar
Region: Arkansas
Send a message via AIM to braumab Send a message via MSN to braumab
Re: Amp Rack
well for starters, can I see a pic of how it's setup?
05 Stang to the Bang! X-Pipe, Headers, Stage 2 Roush Kit, Tuner, JBA Exhaust and about a million and 4 Horsepower.
braumab is offline   Reply With Quote
Old 10-30-2008, 08:22 AM   #3
at7311's Avatar
Re: Amp Rack
Sure i can get one when i get off of work today. If it helps it's the original rack that comes with the car. It has four deep holes centered up in between both hidden amps. The rack, which is more like a cover, stretches from the left to the right of the car.
Old 10-30-2008, 08:57 AM   #4
braumab's Avatar
Region: Arkansas
Re: Amp Rack
is the amp rack positioned over the speakers or under? what size speakers? and what size amps?
Old 10-30-2008, 09:07 AM   #5
at7311's Avatar
Re: Amp Rack
speakers, amps, then the protective amp rack/cover. Again the problem is in the trunk of the car. Hell, not sure about the speakers or amp size. Maybe 6x9's /shrug sholders. The stock mach rear speakers were replaced with alpines (before i bought the car) and the amps I assume are original. I'll get a photo up after work.
Old 10-30-2008, 09:14 AM   #6
braumab's Avatar
Region: Arkansas
Re: Amp Rack
oh. okay . yeah, that's helps me put a picture in my head a bit more. yeah, get a pic. up, we'll see if we can't solve your problem.
Old 10-30-2008, 09:52 AM   #7
at7311's Avatar
Re: Amp Rack
That would be good because it drive me up the freaking wall.
Old 10-30-2008, 10:02 AM   #8
braumab's Avatar
Region: Arkansas
Re: Amp Rack
lol...
Old 10-30-2008, 10:05 AM   #9
1234's Avatar
Re: Amp Rack
I took the bolts out and put locking washers(you can use any washer) so it had different thread to grab.
Old 10-30-2008, 10:10 AM   #10
braumab's Avatar
Region: Arkansas
Re: Amp Rack
or you could also try being in last place with the fantasy football league. I hear that helps too.
Old 10-30-2008, 10:10 AM   #11
at7311's Avatar
Re: Amp Rack
That sounds like a good idea. I'll try taking them out and scoop up some washers at Ace or someplace.
Old 10-30-2008, 10:13 AM   #12
1234's Avatar
Re: Amp Rack
Wait till next year you will be right down there with me. And yes it helps.
Old 10-30-2008, 10:14 AM   #13
braumab's Avatar
Region: Arkansas
Re: Amp Rack
:bs:
Old 10-30-2008, 10:15 AM   #14
1234's Avatar
Re: Amp Rack
I dont remember the size bolt or anything. But i grabbed lock washers for the fact or they are thicker. If i had it to do over again i would grab flat washers.
Old 10-30-2008, 12:25 PM   #15
at7311's Avatar
Re: Amp Rack
only thing is, is if the bolt wasn't grabbing the original threads well in the first place how would a single washer help solve that problem?
Old 10-30-2008, 12:58 PM   #16
braumab's Avatar
Region: Arkansas
Re: Amp Rack
um, it's changing the pattern up a bit by using washers. It's sits up higher ... thus giving it a different angle if you will. I really need a scientist emoticon right about now.
Old 10-30-2008, 12:59 PM   #17
1234's Avatar
Re: Amp Rack
It gives it new thread to grab on to. Ive done it with stripped bolts before. It also seemed to work in this application. Another way is to get a tap and a bigger bolt. Or you may just try thread tape. Ive never done it that way so dont know how long it will hold if at all.
Old 10-30-2008, 01:11 PM   #18
at7311's Avatar
Re: Amp Rack
I will try the washer thing this weekend and if it works, I will celebrate with multiple beers and if it doesn't will probably still have multiple beers just not as happy.
Old 10-30-2008, 02:25 PM   #19
braumab's Avatar
Region: Arkansas
Re: Amp Rack
That's what i said ... :beatyou:
Old 10-30-2008, 03:20 PM   #20
1234's Avatar
Re: Amp Rack
Did you ever stop to think maybe i was typing when you submitted your reply.
Old 10-30-2008, 03:29 PM   #21
Re: Amp Rack
Impossible...the interwebs is an exclusive environment...only one person can type at once.
Old 10-30-2008, 05:36 PM   #22
1234's Avatar
Re: Amp Rack
:blah:
Old 10-31-2008, 08:27 AM   #23
braumab's Avatar
Region: Arkansas
Re: Amp Rack
wned:
rack&pinion for 65 ??? rwood53 Classic Mustangs 11 01-06-2011 06:15 PM
rack & pinion 04TRV6 Pre-2005 V6 Mustang 11 03-08-2010 07:14 PM
460 amp rack removal kcfan_2004 Mustang Audio & Video 0 07-10-2008 12:30 AM
Steering Rack bluemustang 1979-1995 Mustang GT 9 04-30-2007 08:26 AM
Rack and pinion Ponycarman Pre-2005 V6 Mustang 13 06-17-2005 06:27 PM
11:10 AM
