Grinding Noise From Gears - Mustang Evolution
Old 11-15-2008, 05:18 PM   #1
I have a 2004 GT 4.6 V8. The first few times I switch into 5th gear when the car is cold I get a grinding noise from the transmission. Any suggestions on what this could be?
parkerr1 is offline   Reply With Quote
Old 11-17-2008, 07:28 AM   #2
Re: Grinding Noise From Gears
5th gear is weak on those transmissions~ just a sign of wear. My 01 v6 did it on a T-5 every now and then. Have you ever changed the transmission fluid? hmmm well you should. Will it help it? Nope probably not but it will help future wear a bit if the fluid is more fresh.
My suggestion is to take it into neutral let it sit for a sec then ease it in when its cold~
Old 12-08-2008, 01:46 PM   #3
Region: Montana
my car was doing that not to long ago only 5th gear would grind and then it went to 3rd and 4th my sister and i dropped out my tranny and had to get all new clutch kit my clutch just stopped and would not relase and throw out bearing was shot so had to replace that while i was in there.
97cobraGal is offline   Reply With Quote
Old 12-08-2008, 02:13 PM   #4
try pushing the clutch in.....just kidding, the syncros are probably starting to wear in 5th, change the fluisd and run some atf stabilizer and itll help.
SimplyOrange is offline   Reply With Quote
Old 12-08-2008, 02:49 PM   #5
MonteCitan's Avatar
TR3650 is KNOWN for this when the trans is cold - there is a TSB on the issue at Ford dealers I believe - not sure if 5th gear is specified, but I'm pretty sure its all related
I'd had mine rebuilt at 26k miles for this same problem into second/third and fifth when cold
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 12-16-2008, 05:34 PM   #6
DaDant!'s Avatar
here is a cheap simple fix. change the trans oil put the atf stabillizer in it. and either A. get a remote start and start your car about 5 minutes before you need to leave or B. go out side and start your car 5 minutes before you need to leave. give it some time to worm up. i know this is off subject but by doing that you will increase the life of your engine, by letting it idle for 3 minutes it alows the oil in the engine to completely cover your pistons to reduce wear. compared to just turning it on a driving off.
00 gt:u.d. pulleys, K&N CAI, UPR O/R X-pipe, Flowmaster 40 tips
im getting there.
DaDant! is offline   Reply With Quote
Grinding in second BAgee87 1996-2004 Mustang GT 4 10-14-2008 09:05 AM
Clicking Noise kind of Squeeky Noise... braumab 2005-2010 Mustang GT 23 06-29-2008 11:24 PM
loud grinding noise! roach 1996-2004 Mustang GT 13 03-24-2008 10:01 AM
grinding noise from pass. front jimmy_beaner 1996-2004 Mustang GT 3 12-17-2006 07:37 AM
grinding noise from diff. Horse Pre-2005 V6 Mustang 8 04-27-2004 04:47 PM
11:52 AM
