Rear alignment? - Mustang Evolution
Old 12-12-2008, 03:44 PM   #1
Foxone's Avatar
Rear alignment?
I have an 04 V6 that was recently hit in the back from the side, the guy hit it right smack in the drivers side wheel (And kept going) Ive had the car repainted in the damaged areas, new rear wheel and they installed a whole new rear axle. The issue is they cant get it aligned.It pulls right BAD. Is there something in the back that might need adjusting? Im going to climb under there this weekend and look around. I dont see how the axle could be bent, but nothing else.
Foxone is offline   Reply With Quote
Old 12-12-2008, 04:18 PM   #2
Zim
You want to **** me?
Zim's Avatar
Re: Rear alignment?
You can't adjust the alignment on a solid rear axle. Its most likely a bent control arm, or bent subframe problem. Somethings bent from the accident... sounds like it wasn't fixed correctly to me.
I like toys
Old 12-13-2008, 10:09 AM   #3
Re: Rear alignment?
yea the rear end bolts pretty much to the frame and has no alignment on it. That means its probably the frame thats bent or the used the control arms that were on it and they are bent.
Old 12-13-2008, 10:52 PM   #4
MonteCitan's Avatar
Re: Rear alignment?
it's more than likely the control arms, just due to the fact that they tend to bend before the frame/unibody..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
alignment points gearbanger67 Classic Mustangs 3 06-15-2007 08:09 AM
Alignment Issues bodavenport 1996-2004 Mustang GT 4 12-08-2006 12:45 PM
frame alignment Dark02Pony Pre-2005 V6 Mustang 13 12-20-2005 10:12 AM
Alignment problem stang-rookie Pre-2005 V6 Mustang 13 06-14-2005 08:35 AM
alignment question BlueDonkey Pre-2005 V6 Mustang 5 02-28-2004 08:17 PM
08:16 AM
