March 2013 MOTM Winner - Scott2! - Mustang Evolution
Go Back   Mustang Evolution > Mustang Evolution | Community Forums > Mustang of the Month > Mustang of the Month Winners
Old 03-01-2013, 05:45 PM   #1
Everyone give Scott2 and his awesome 2008 GT/CS a big congrats for winning this month's Mustang of the month!!
Scott's GT/CS :: 2008 Ford Mustang GT/CS
Old 03-01-2013, 06:04 PM   #2
It's not me, it's you.
primer2tone's Avatar
Congratulations meng! Sexy ride!
Old 03-01-2013, 06:05 PM   #3
Gratz man! awesome ride!
DallasVictory is offline   Reply With Quote
Old 03-01-2013, 06:18 PM   #4
06GTStang's Avatar
Congrats Scott! Well deserved!
06GTStang is offline   Reply With Quote
Old 03-01-2013, 06:53 PM   #5
Awesome, well deserved!
2000 Atlantic Blue GT
paradigm is offline   Reply With Quote
Old 03-01-2013, 08:18 PM   #6
Hmiller's Avatar
Send a message via AIM to Hmiller
Congrats!!!!
VOTE For MOTM!!!!!!
Hmiller is offline   Reply With Quote
Old 03-02-2013, 08:47 AM   #7
Scott2's Avatar
Thanks everyone!
I have been keeping busy on the build. Only one little mistake so far (at least that I am aware of). For degreeing the cams I should have temporarily installed a solid valve adjuster on one of the #1 intake valves. No dig deal just need to Re & Re the RH Cam.
Cams and Cam Phasers installed.
Old 03-02-2013, 09:02 AM   #8
bullitt1075's Avatar
Send a message via Skype™ to bullitt1075
Congrats!
Proud owner of Bullitt #1075
bullitt1075 is offline   Reply With Quote
Old 03-02-2013, 09:17 AM   #9
GTdevildriver's Avatar
Region: Arkansas
Looks awesome dude!
I Could ****ing Care Less.
GTdevildriver is offline   Reply With Quote
Old 03-03-2013, 05:00 PM   #10
08SteedaQ350's Avatar
Beautiful Stang. Congrats
08SteedaQ350 is offline   Reply With Quote
Old 03-03-2013, 09:06 PM   #11
93slowstang's Avatar
Congrats.
Old 03-03-2013, 09:11 PM   #12
1lowGT's Avatar
Nice! Congrats.
Old 03-03-2013, 09:19 PM   #13
Go scot wit them fatazzzz tires
Old 03-06-2013, 02:47 PM   #14
Scott2's Avatar
Thanks guys, still making progress slowly.
Old 03-06-2013, 02:51 PM   #15
Venomouz831's Avatar
Congrats and well deserved
)02 Gt, Founder of WE2G
Old 03-08-2013, 12:20 PM   #16
Scott2's Avatar
Thanks!
Just picked up a Comp Cams Crankshaft Socket that lets you rotate the degree wheel without the risk of rotating the crankshaft. NEAT!
Ready to locate TDC and check the cam timing, but first I need to come up with a better, more rigid way of fixing the pointer.
Old 03-09-2013, 08:59 PM   #17
13ShelbyGTS's Avatar
Congrats!
13ShelbyGTS is offline   Reply With Quote
Old 03-16-2013, 08:10 AM   #18
Lorraine's driver
ab_mach1's Avatar
Congrats Scott!
Instagram: @ab_mach1
Old 03-16-2013, 09:28 AM   #19
Boomdizzle's Avatar
Congrats man! Looks like one sweet ride. Good luck on the build, definitely jealous!
Torque: It's like crack for your right foot
Boomdizzle is offline   Reply With Quote
Old 03-26-2013, 05:04 PM   #20
Scott2's Avatar
Originally Posted by 13ShelbyGTS View Post
Congrats!
Congrats Scott!
Thanks guys!
Still not ready to check the cam timing.
Waiting for a second TFS Solid Lash Adjuster. I did modify two Roller Followers so an Allen key will pass through the oil hole. OEM left, TFS Lash Adjuster middle and modified Follower on the right.
Also fabricated a 12mm thread Piston Stop (bottom) as no one seems to make one.
Old 03-26-2013, 06:50 PM   #21
Lorraine's driver
ab_mach1's Avatar
Originally Posted by Scott2 View Post
Thanks guys!
Very cool!
Do the lifters always remain primed as the engine runs? Also, is the increased size hole on the rocker just for rocker-lifter lubrication? Sorry if these are dumb questions. Lol
Old 03-26-2013, 07:24 PM   #22
Scott2's Avatar
Yes, oil constantly flows through the Hydraulic Lash Adjusters.
The hole is used to pass an Allen Key though to be able to set the clearance to "zero lash" between the lash adjuster and the roller follower. This is done as part of checking the cam timing - literally to take up the slack. The Roller Followers that I modified are only used when checking the cams.
This pictures shows the Allen Key passing through the Roller Follower in order to adjust the set screw in the TFS Lash Adjuster.
Old 06-01-2013, 03:51 PM   #23
Scott2's Avatar
The forged motor is in, still some tinkering, break-in and tuning to do:
Old 06-01-2013, 05:17 PM   #24
DWC_SmOziLLa's Avatar
Absolutely gorgeous dude. Can't wait to see the numbers. You're doing the 4.6 proud. I definitely know I voted for the right person.
Old 06-11-2013, 08:15 PM   #25
Scott2's Avatar
Thanks, your vote was greatly appreciated as it was a very close race!
Here is a little better picture of the installed forged engine.
05:49 PM
