BBK 70mm throttle body - Mustang Evolution
Old 03-15-2011, 02:01 AM   #1
Has anybody had any problems setting the tps just right
Tribulation06 is offline   Reply With Quote
Old 03-15-2011, 02:14 AM   #2
Bbk isn't a very good piece. I have not heard many good reviews. Are you referring to the little idle screw or what exactly is the problem. Give me some details and I will what I can do for ya
Built 2 Last TTT
Old 03-15-2011, 08:10 AM   #3
Well my stock tps is at 1.38 and when I put my new throttle body at that setting it works like it's supposed to. And yes I am referring to adjusting the idle screw. When I would open on the streets at about 125mph I would loose throttle response and tge angry wrench would come on.
Old 03-15-2011, 08:35 AM   #4
K so are you thinking that maybe the blade isn't opening all the way. Do you have a cai/tune or any other intake mods or is it the stock tune. Did you flash a canned tune onto the ecu. I am just taking stabs in the dark here. I am more familiar with a 2v. I hope someone hops in here
PETOM.biz TTT
Old 03-15-2011, 08:37 AM   #5
No tune just a CAI and the throttle body and I also just got the steeda spacer if that might help
Old 03-15-2011, 08:53 AM   #6
There's your problem. Your getting more volume of air and the ecu isn't compensating with enough fuel. Either get a tuner or start removing pieces til it runs right again. Just a stab in the dark here. Take that spacer out first then take it out for a run. If it still does it put the stocker back on til you can get it tuned for your mods
PETOM.biz TTT
Old 03-15-2011, 11:43 AM   #7
What type of tune should I put in
Old 03-15-2011, 11:48 AM   #8
Go put the highest octane you can get then flash the appropriate tune. See how that works
PETOM.biz TTT
Old 03-15-2011, 02:32 PM   #9
stampde's Avatar
Re: BBK 70mm throttle body
I Put a BBK t-body in my Mach 1 and had NOTHING BUT PROBLEMS !!!!!!!
I would NEVER buy another one ...........
2011 GT Auto
Old 03-15-2011, 09:15 PM   #10
That's not the first time I have heard that about bbk throttle bodies. There is a reason why Accufab costs double. I have a 70mm Accufab and I could really tell the difference over the 65mm stocker
PETOM.biz TTT
BBK 70mm Throttle Body install rstewart Pre-2005 V6 Mustang 11 11-18-2008 12:16 PM
70mm V6 throttle body help skylar1926 Pre-2005 V6 Mustang 23 09-02-2004 08:17 PM
$150 For Sale NEW BBK 70mm throttle body for 3.8L V6 2001-2003 bumlebee Mustang Parts for Sale and Wanted 2 07-31-2004 09:54 AM
06:58 AM
