Will a Gt500 super charger fit and run in a 4.0 2010 v6 - Mustang Evolution
Old 05-05-2011, 07:22 AM   #1
Title says it all, anyone know?
Tippy is offline   Reply With Quote
Old 05-05-2011, 07:29 AM   #2
Joshy's Avatar
I don't think it will without some major modification.
www.petom.biz
Joshy is offline   Reply With Quote
Old 05-05-2011, 08:25 AM   #3
Re: Will a Gt500 super charger fit and run in a 4.0 2010 v6
it wont just bolt on but where there is a will there is a way many have made the supercharger from the 03/04 cobra work on their 3.8L and some on the 4.0 I believe so it is possible. The issue you are going to run into is cooling and clearance. The hood may not work and the stock setups are cooled by water, you REALLY REALLY need this or some type of cooling. A standard air/air intercooler will not work due to the compression is right on top of the motor. The only other alternative rather than a water/air heat exchanger cooling solution is methanol and thats just a band aid to me at least.
Old 05-05-2011, 10:11 AM   #4
Well ive found a couple of the superchargers for only 700 , compared to paying 5 grand for a new one . If I were to purchase a new hood and change all my coolants it'd probably cost 2400 for all the parts. Only problem is that I have no clue how to do this freehand , I'd need a guide of some sort
Old 05-05-2011, 10:14 AM   #5
there is no direct bolt up, you will have to have something to match the supercharger up to the intake, thats custom fab work if someone has not done it already... you are looking at a costly setup regardless.
It might be better to look towards a centrifugal setup like vortech or procharger so you can have a cooling solution.... it will probably cost you 5-6k that route when done vs probably 3-4k for the GT500 or some other positive displacement blower.
Keep in mind the GT500 super charger or the 03/04 Cobra supercharger are Eaton brand are not twin screw blowers, they are root blowers and not nearly as efficient as twin screws (they wont make as much power per psi you put in them) and they run hotter.
Whipple or KB one is coming out with a blower that has coolant lines INSIDE it not just through the normal attached intercooler that generally sits under them.
Old 05-05-2011, 10:15 AM   #6
WildBill's Avatar
LOL..........Tippy..............it's not that easy!
WildBill is offline   Reply With Quote
Old 05-05-2011, 10:18 AM   #7
Hah, that's why I came here to ask. Thanks for the remarks , I'm probably just going to end up engine swapping cause there's no way I can get over 325~ whp without spending 3-5 grand
Old 05-05-2011, 10:52 AM   #8
WildBill's Avatar
That's KB.
That's only for cooling of the blower.
The facts are the KBs heat up quickly. That LC variant is NEEDED by KB.
Old 05-05-2011, 10:57 AM   #9
WildBill's Avatar
ProCharger does make a very nice kit for your car and you'll make over 325RWHP with it.
Swapping over a 4.6 will cost you over $5k
Old 05-05-2011, 11:23 AM   #10
dont swap motors, sell your car and buy something else and this will save you tons of money down the line. Just something to think about~ the value of a vehicle that has a swaped motor is VERY low plus you have to inform your insurance etc etc
looking for procharger or super charger saleenman 1996-2004 Mustang GT 5 11-27-2009 02:41 PM
2010 Shelby GT500 Super snake SVTCOBRA General Mustang Discussion 8 08-04-2009 09:37 AM
super charger on the cheap hottcobra General Mustang Discussion 11 01-07-2008 11:30 PM
Ran across this super charger Cajun JungleBoy Pre-2005 V6 Mustang 9 04-14-2006 07:14 PM
super charger question oaktonarcher Pre-2005 V6 Mustang 4 03-03-2004 03:37 PM
12:45 AM
