Clutch issue.Hey gu - Mustang Evolution
Old 05-31-2011, 09:31 AM   #1
Clutch issue.Hey gu
Hey guys first post on here. I was driving up the road shifted my 2005 v6, 86 000km, into 2nd and the clutch peddle didnt come back up. There has been some jerkyness in first gear when accelerating. Then a screaming noise then the dredded shift into second where it all ended. Funny part was when it happened i didnt want to shut the car off so i had to get to the shop , On the way to the shop there was a one way bridge and a very steep hill after it . I stalled and had to get er towed the mechanic is busy as hell said it will take a week to look at the car. Just wondering if you guys think the clutch is gone and shoud i just order one. i need the car back asap and it could save some time to have the clutch on hand. Thanks.
Kenny is offline   Reply With Quote
Old 05-31-2011, 10:17 AM   #2
wereKEV's Avatar
Re: Clutch issue.Hey gu
sounds like the slave cylinder went out if it is a hydraulic clutch or a clutch spring broke maybe.
wereKEV is offline   Reply With Quote
Old 05-31-2011, 11:42 AM   #3
yea check the fluid level that might be most of it, then the linkage if the fluid is ok. Finally look for leaks.
Old 05-31-2011, 06:36 PM   #4
Thanks for the replies if the Clutch is gone, any opinions on what clutch would be a replacement.?
Old 06-01-2011, 09:43 AM   #5
wereKEV's Avatar
There is a lot to choose from.
Old 06-01-2011, 10:53 AM   #6
OEM is fine unless you want more power (above what the clutch can hold)
Old 06-01-2011, 10:58 AM   #7
wereKEV's Avatar
true that
Old 06-07-2011, 09:28 AM   #8
Your slave gave out. Resurface your flywheel ($40) and get a new clutch, if you have any mods, it's time to upgrade, spec makes some for the 05+ mustangs. The slave cylinder you'll need to get from ford.
254S197 is offline   Reply With Quote
2000 V6 clutch/shifting issue audio75 Pre-2005 V6 Mustang 10 07-31-2010 11:41 PM
Clutch smell issue Rich_Guy 1996-2004 Mustang GT 7 07-14-2009 09:56 PM
need help with a serious issue Kyle The Bar 13 04-22-2005 07:48 PM
Getting The Last Issue Dan The Bar 7 01-14-2004 02:54 AM
clutch issue for the 56# time lol SpectorV Pre-2005 V6 Mustang 1 05-12-2003 07:00 PM
11:35 AM
