Overdrive - Mustang Evolution
Old 07-07-2011, 10:12 PM   #1
Holdempoker102's Avatar
Overdrive
Quick question... Should I use overdrive? What does it do? And should I use it when I race? Also when racing am I better off keeping it in Drive or should I shift it manually? Pros and cons of auto shift and myself manual
Thanks everyone I know kinda newbie questions!
Holdempoker102 is offline   Reply With Quote
Old 07-07-2011, 10:42 PM   #2
GoldenPonyBoy's Avatar
Overdrive off allows the engine to rev higher before shifting, using more gas so if your racing or just wanna let loose do it but for gas reasons don't do it. And standard driving is the same... Fun for showing off and driving but could blow the engine and uses more gas
"Stay golden"
GoldenPonyBoy is offline   Reply With Quote
Old 07-07-2011, 11:00 PM   #3
Send a message via Skype™ to Texastboneking
All overdrive is is your forth gear. If your pulling a load you turn it off so that it's easier on your torque converter. It will mess with your shift points some but will not raise your rev limiter.
Texastboneking is offline   Reply With Quote
Old 07-08-2011, 08:20 AM   #4
Thanks for the quick responses guys!
Old 07-09-2011, 01:57 PM   #5
Mine does, if I'm not using od off I shift at 1 1/2 rpms, if od is off I rev up to 2 1/2-3 before I shift
"Stay golden"
Old 07-09-2011, 02:53 PM   #6
That's not your rev limiter
Like I said it will raise your shift points for daily driving. But when you punch it with od on or off you will still have the same rev limiter
Old 07-09-2011, 05:48 PM   #7
Oh okay, I gotcha
"Stay golden"
05:04 AM
