Rear axle fluid - Mustang Evolution
Old 07-13-2011, 09:23 AM   #1
Holdempoker102's Avatar
Rear axle fluid
Hey guys! I was just on firestones website and it says at around 45000 miles (I have 44000 on the car) I should do a rear axle fluid replace. Is this them just trying to make a sale or will I actually need this? This is my first mustang so if this is a stupid question I am kinda a newbie!
If I do need it what brand fluid do you suggest?!?
Thanks!
Holdempoker102 is offline   Reply With Quote
Old 07-13-2011, 10:52 AM   #2
Texasboneking, please report to this thread immediately. One again, calling texasboneking
DrSalt22 is offline   Reply With Quote
Old 07-13-2011, 11:16 AM   #3
DarkShadows's Avatar
I do mine every thirty thousand. But I do alot of heavy racing. 45000 is about right. when you do it, don't forget your limited slip additive.
March 2010 Mustangevolution Mustang of the Month 1st eva biatch!
DarkShadows is offline   Reply With Quote
Old 07-13-2011, 11:44 AM   #4
wc3john's Avatar
Re: Rear axle fluid
+1...
where is he, he usually is on this forum 24/7
darkshadows has a pretty good answer, but what throws me is that my service manual on my truck, (no posi unit) says change it at every 100,000 k... now while thats a truck and an 8.8, I dont see why a light duty rear-end (yours) would need to be changed less... Regardless, good luck!
I chug syrup for money...
wc3john is offline   Reply With Quote
Old 07-13-2011, 01:02 PM   #5
Ended up going to firestone for my sisters tires...well I was there one of the guys told me that ford calls for a replacement every 3000 miles but he thinks that way overdoing it since it's about 100$ every replacement!
Thanks for the responses! Also does Texan know alot about this? Should I just message him directly?!
Old 07-13-2011, 01:19 PM   #6
Re: Rear axle fluid
the OEM rear end fluid is generally good to 100k, but you can change it if you want you just have to remove the diff cover since they dont have a drain... or suck it out.
Old 07-14-2011, 08:39 AM   #7
Originally Posted by wc3john
+1...
My rear posi went out at 60k So trust me when I say, 100k might be a hair too long to wait.
Old 07-14-2011, 03:05 PM   #8
wc3john's Avatar
Re: Rear axle fluid
I wasnt saying your wrong, just that it doesnt make sense to me.
Old 07-14-2011, 07:56 PM   #9
Being that the posi in the mustangs are a clutch type, it would require more frequent changes.
Rear wheel and tire size poloka 2011-2014 Mustang GT 11 07-27-2011 07:44 AM
03 v6 rear brake help TaylorF25 General Mustang Discussion 2 07-11-2011 03:58 PM
Rear diff fluid 96 stang General Mustang Discussion 12 06-27-2011 06:10 PM
What Brake Fluid do you use? 99ford General Mustang Discussion 1 06-27-2011 09:34 AM
03 v6 rear brakes TaylorF25 Pre-2005 V6 Mustang 8 06-25-2011 10:01 PM
02:26 AM
