Comp 800 Racing Wing - Mustang Evolution
Old 07-16-2011, 10:13 PM   #1
gonzo56's Avatar
Region: New Mexico
Hello V6 Stang Fans! Its been a few months since I have droped a line. I have relocated to Rio Rancho Nm. I was working a race in Albuquerque Nm. This 2008 Stang had this Wing. Driver loved it. He won the race! Anybody have any comments to share?
Competition Performance Products
Size: 12" chord width by 68" long, other non-standard lengths are available.
Weight: Approx. 7.5 lbs., excluding End Plates and Struts.
Downforce Range: 0 to 600 LB at 120 mph*
Speed Rating: 240 mph
Construction: Proprietary carbon fiber and epoxy construction with structural polyurethane foam core.
Finish: Clear Gelcoat or Grey urethane primer, ready to paint.
Strut Center Distance range: 18 to 44 inches
Purchased 2006 v6 Mustang Coupe May 20, 2006 Diablosport Predator 91 Octane tune
Tru Dual Exhaust
VCT Scarface II [chrome] Rims 20x8.5
Hankook Tires RH07
PIAA 004XT Professional Halogen Lamp System
Ultimate Racing Pedals
gonzo56 is offline   Reply With Quote
Old 07-17-2011, 12:16 AM   #2
Seems nice for a high end 500+ horse power car but I feel like it would be too ricey for a mustang.
Tippy is offline   Reply With Quote
Old 07-17-2011, 07:01 AM   #3
Titus Wadicus
svtlx's Avatar
Re: Comp 800 Racing Wing
i like the sn95 body kit.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 07-17-2011, 09:58 AM   #4
wereKEV's Avatar
Yes it sounds like a bit much for a street car especially a stang.
wereKEV is offline   Reply With Quote
Old 07-20-2011, 04:15 PM   #5
GoldenPonyBoy's Avatar
Do you do any autocross?
"Stay golden"
GoldenPonyBoy is offline   Reply With Quote
04:20 AM
