what to do next? - Mustang Evolution
Old 07-23-2011, 12:09 AM   #1
what to do next?
2008 4.0 convertible, all leather, chrome accents on vents, true dual exhaust, x-pipe, gt take off mufflers, taylor street thunder 8mm spark plug wires, platinum plugs, K & N cai, 3.31 gears, hurst shifter, gt sway bars, front and rear, frame braces underneath, shaker 500 stereo.
I can't decide on what to do next, car is very quick, and sounds decent, any help would be appreciated.
thanks
Jimstang is offline   Reply With Quote
Old 07-23-2011, 12:21 AM   #2
Massive turbo!
16218 is offline   Reply With Quote
Old 07-23-2011, 12:25 AM   #3
1gt289's Avatar
New rims? Smoked tail lights? Sound system? Cobra bumper?
1gt289 is offline   Reply With Quote
Old 07-23-2011, 09:55 AM   #4
wereKEV's Avatar
Re: what to do next?
At the end of the day it's all up to you.
wereKEV is offline   Reply With Quote
Old 07-23-2011, 12:20 PM   #5
1gt289's Avatar
Exactly
Old 07-23-2011, 01:40 PM   #6
goherd's Avatar
You cab do the 70 mil throttle body. The screaming demon coil pack. Possibly the xcharger kit.
goherd is offline   Reply With Quote
Old 07-23-2011, 01:47 PM   #7
Titus Wadicus
svtlx's Avatar
ITS BLOWER TIME!!!
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 07-23-2011, 05:28 PM   #8
thanks for all the replies, will probably save up for x-charger, and rims, thanks for comments.
Old 07-26-2011, 04:43 PM   #9
tylerb's Avatar
what's the screamin demon coil pack do
tylerb is offline   Reply With Quote
Old 07-26-2011, 05:20 PM   #10
goherd's Avatar
It is suppose to deliver a hotter spark to the plugs.
Old 07-26-2011, 05:50 PM   #11
scorpiouno's Avatar
My mind is salivating!
scorpiouno is offline   Reply With Quote
Old 07-26-2011, 06:54 PM   #12
1gt289's Avatar
Does it add much power?
Old 07-27-2011, 08:52 AM   #13
goherd's Avatar
Hard to tell unless you dyno the car. The theory is that a hotter spark will burn the fuel more efficiently thus increasing horsepower.
04:59 PM
