'05 V6 coolant leak? - Mustang Evolution
Old 07-28-2011, 11:23 PM   #1
afree05's Avatar
I have a 2005 v6 'stang and today I had the unpleasant experience of a coolant leak.
I tried replacing the thermostat o ring and such but I noticed during that, it was leaking from just below the thermostat.
It was coming from the bean shaped box that the thermostat assmbly was bolted to.
I need to know what that box is called so I can get another one tomorrow.
it's about 4-6 inches long, three ish deep and about three wide. it gas two hoses connected to it, one smaller one on the top, and a larger one on the bottom. the thermostat assmbly is held to it with three bolts.
can you tell me what this thing is called?,
any help would be much obliged.
thanks.
afree05 is offline   Reply With Quote
Old 07-28-2011, 11:31 PM   #2
Re: '05 V6 coolant leak?
thermostat housing
IamtheMAN is offline   Reply With Quote
Old 07-28-2011, 11:45 PM   #3
afree05's Avatar
I'm thinking the lower thermostat housing?
Old 07-28-2011, 11:46 PM   #4
Las0mbra's Avatar
Can you post a pic?
Old 07-28-2011, 11:47 PM   #5
afree05's Avatar
I knew there was a thermostat housing, I just wasent shure. thanks a million!
Old 07-29-2011, 12:36 AM   #6
emeres13's Avatar
Had the same issue at 47k miles really easy to fix tho, I recomend not only changing the bottom part get the top and bottom, once u take them apart the sealing won't be the same on used parts, also consider changing the hoses at this point
emeres13 is offline   Reply With Quote
Old 07-29-2011, 12:40 AM   #7
Las0mbra's Avatar
+1 the used parts might be warped.
Old 07-29-2011, 12:52 AM   #8
emeres13's Avatar
Let's keep it neat
Old 07-29-2011, 09:38 AM   #9
afree05's Avatar
Originally Posted by Las0mbra
Can you post a pic?
I can't, I'm on my iPhone, it won't let me.
Old 07-29-2011, 09:40 AM   #10
afree05's Avatar
okay, thanks guys for the info, ill check and see if the auto parts stores around here have any in stock!, and all if the hoses look fine, but I'll look into that too, shouldn't be too much.
Old 07-30-2011, 09:53 AM   #11
afree05's Avatar
okay, I replaced all the thermostat housing, but it still leaks.
it leaks up close to the firewall, I can't see where from, but it almost seems like it's coming in top if the transmission and splitting into two streams. heater core maybe?
Old 07-30-2011, 03:52 PM   #12
emeres13's Avatar
That a Ford part even the one u can get from AM online has a Ford logo and serial ...no autoparts have em
Old 07-30-2011, 04:19 PM   #13
afree05's Avatar
they had at at a local Carquest, well they had to order it, but the had it within a few hours.
Old 07-30-2011, 10:40 PM   #14
GTtopgear's Avatar
Could be the intake manifold
02 GT : LT headers, H pipe, Cat back, 80mm TB, Intake, Strut tower bar, lightweight pullies All BBK, drilled and slotted rotors, Clear headlights, Eibach Pro Kit, Hid kit for both head and fog, chin spoiler,18' chrome 2010 GT wheels with nitto tires
GTtopgear is offline   Reply With Quote
Old 07-31-2011, 04:33 PM   #15
afree05's Avatar
the weird thing is, it's not draining any from the reservoir., maybe it's just heavy ac condensation?
Old 07-31-2011, 05:08 PM   #16
emeres13's Avatar
U said it divides into two streams...
Check if it has pressure, if it does its not condensation
Anyways wanna make sure if its ur coolant leaking get a radiator cap with a pressure gauge on it I've seen them on some autoparts...that would tell u if there is a leak
Old 08-01-2011, 01:13 AM   #17
scorpiouno's Avatar
Are you using the browser?! Download the app and you can post photos.
scorpiouno is offline   Reply With Quote
Old 09-22-2011, 09:26 PM   #18
Byrd92's Avatar
Thermostat housing! Onthe v6 its not vry stout cheap fix hour job
Byrd92 is offline   Reply With Quote
Old 09-24-2011, 03:42 AM   #19
CancerBoi69's Avatar
Hey I have the same to leaks also. Mine started happening when the honeycomb in my cats broke apart and shot down my pipes. Weird how that happened. I two replaced the thermo. Housing make sure you replace the senor n the pin also
CancerBoi69 is offline   Reply With Quote
1999 mustang v6 cat back C4king Pre-2005 V6 Mustang 8 07-29-2011 09:33 AM
88 fox oil leak 04TRV6 1979-1995 Mustang GT 4 07-05-2011 01:17 PM
ordering 12 mustang v6. need opinions SoFlo Mustang 2011-2014 V6 Mustang 17 07-05-2011 08:02 AM
horrible coolant leak...ideas? shustwit Pre-2005 V6 Mustang 3 06-30-2011 12:48 PM
04:25 PM
