Right blinker - Mustang Evolution
Old 08-13-2011, 05:03 PM   #1
Gmullinix's Avatar
Right blinker
Ok guys. I have replaced my rear and front right blinker bulbs and it is flashing twice as fast as it normally should. what do I do to fix this???
Gmullinix is offline   Reply With Quote
Old 08-13-2011, 06:01 PM   #2
Filibuster
Make sure you have the right bulb front and back..bulbs have different resistance that can cause the flasher to pulse faster...
If all the lights are correct and it still happens its the flasher..
XXSTEVEO66 is offline   Reply With Quote
Old 08-13-2011, 07:58 PM   #3
Gmullinix's Avatar
I checked the bulbs and they are the right ones. I got them from advanced and I made sure they were in there right. How would I install a new flasher?
Old 08-13-2011, 08:57 PM   #4
Filibuster
Should be in the fuse box...though they dont usually go bad that often I would check for good conections first i.e. proper ground,corrosion and so on...
Old 08-13-2011, 09:36 PM   #5
Gmullinix's Avatar
Alright thanks
Old 08-13-2011, 10:41 PM   #6
Loc: Austin,TX
Re: Right blinker
Fuse issue.
Old 08-14-2011, 10:54 AM   #7
wereKEV's Avatar
Re: Right blinker
sounds like a fuse or a bad flasher.
wereKEV is offline   Reply With Quote
fast blinker - lights all good sattwood General Mustang Discussion 2 07-04-2011 08:01 PM
03:29 AM
