turbo advice please. - Mustang Evolution
Old 09-07-2011, 09:27 PM   #1
kirpy's Avatar
I have a 2005 4.0 v6. Im looking into turboing it. I just want to know how well does it work? What are good brands to go with? Im shooting for 500 hp. And im trying to keep it under 7 grand. Any advice will be gratefully appreciated. Thanks
kirpy is offline   Reply With Quote
Old 09-07-2011, 09:36 PM   #2
Redmustang2007's Avatar
American muscle has them
Redmustang2007 is offline   Reply With Quote
Old 09-08-2011, 03:17 AM   #3
You'll never brake 500 hp unless you manage to twin turbo it and in that case itd probably cost 10k cause you'll have to change your inter cooling as well. Better off with a engine swap
Tippy is offline   Reply With Quote
Old 09-08-2011, 05:26 PM   #4
kirpy's Avatar
Re: turbo advice please.
I want to keep it a v6. I dont want the weight of a v8. Has anyone used a universal turbo kit? How well do they bolt up? And does anyone know where I should go for low compression pistons and different cams and what not? Im just trying to get all my eggs in one basket. Its going to be a winter project. Thanks kirpy
Old 09-09-2011, 08:22 AM   #5
you can easily brake 500hp with the correct setup single turbo system, the problem is your motor wont take it... you wont be able to do it for 5k either unless you are VERY handy can can develop the piping/headers yourself.. and even then the motor is not strong enough to take that much hp/tq so you will have to build the engine.
I would say 350rwhp is about the limit to be safe and keep it a daily driver. That would be about 425 at the flywheel hp wise.
the universal kits are probably mostly junk, its going to be an expensive one off project, the engine build to do it right will cost a ton (not sure depends on how deep you go but could be 3k-6k) then the turbo setup expect 6k~ then another 1k for tuning and probably another 1k for misc crap that you figure out on the way lol.
is weight really worth that much? What are you needing low weight for? if its autox a turboed car may not be the best way to go.
Old 09-09-2011, 08:38 AM   #6
scorpiouno's Avatar
Always amazed by the detail of your posts!
scorpiouno is offline   Reply With Quote
turbo mystang50 1979-1995 Mustang GT 10 08-24-2011 12:06 AM
Advice 89white GT General Car Discussion 11 08-17-2011 04:38 PM
Turbo DrSalt22 2005-2010 V6 Mustang 7 07-17-2011 01:21 PM
Turbo and tranny Z06 eater 1979-1995 Mustang GT 5 07-12-2011 10:10 PM
01:58 PM
