Rear wheel spacers - Mustang Evolution
Old 10-19-2011, 11:16 AM   #1
Rear wheel spacers
Was wondering if some one could give me an installation price for rear wheel spacers.
Tippy is offline   Reply With Quote
Old 10-19-2011, 11:55 AM   #2
mystang50's Avatar
Re: Rear wheel spacers
umm u jus take tire off slip them on and then put tire back on.
Old 10-19-2011, 01:06 PM   #3
I don't have a power wrench for the lugs so would rather not do it myself
Old 10-19-2011, 01:47 PM   #4
00STANG00's Avatar
Send a message via AIM to 00STANG00 Send a message via Yahoo to 00STANG00
you dont need a power wrench just little elbow grease.
SUCK MY DUST
00STANG00 is offline   Reply With Quote
Old 10-19-2011, 02:01 PM   #5
If you don't have a torque wrench to retorque the lug nuts, take it to a local service station. They shouldn't charge over $15-$30 to R&R the wheels.
Old 10-19-2011, 03:21 PM   #6
mystang50's Avatar
what is the tq value??
Old 10-19-2011, 08:00 PM   #7
Mustangguy0202's Avatar
Just an FYI I actually had to cut my studs shorter in order to make everything tighten up correctly
Mustangguy0202 is offline   Reply With Quote
Old 10-19-2011, 10:17 PM   #8
This is a problem im seeing. Im getting 1 or 1.5 inch spacers for a 10 v6
Old 10-19-2011, 10:17 PM   #9
Usually between 80-95 ft. lbs. depending on the diameter of your stud.
If you have your owner's manual it is listed in there.
Old 10-19-2011, 10:19 PM   #10
That's strange.
Adding a spacer I would think that you would need longer studs?
Old 10-20-2011, 01:45 AM   #11
deadsp0t's Avatar
Umm could you elaborate, because that defies intuitive logic. Seriously.
That's unimpressive
Old 10-20-2011, 01:48 AM   #12
It's not me, it's you.
primer2tone's Avatar
Lol... Word.
Old 10-20-2011, 07:21 PM   #13
The spacer has holes the studs slide through which holds the spacer in place then the wheel goes on the new studs that are attached to the spacer... The wheel would not tighten flush to the spacer due to the original studs coming through too far.... So I cut them short re thread them and problem solved.... Not that difficult to understand
---------- Post added at 08:21 PM ---------- Previous post was at 08:20 PM ----------
That's strange.
New studs come attached to the spacer... Old studs hold the spacer new ones hold the wheel...
Old 10-20-2011, 08:58 PM   #14
Ok, you are referring to the adapter style spacer.
Thanks, that had me a bit confused as most spacers fit over the existing studs.
Old 10-20-2011, 10:52 PM   #15
deadsp0t's Avatar
+ same here was literally scratching my noggin
That's unimpressive
Rear end swap bmabbott Pre-2005 V6 Mustang 9 10-01-2011 12:14 AM
wheel and tire size 95GT 1979-1995 Mustang GT 2 09-17-2011 05:33 AM
Wheel spacers opinions gregtommy 2011-2014 Mustang GT 49 09-04-2011 09:11 AM
Help on spacers, Please..... BLUE02GT 1996-2004 Mustang GT 1 08-23-2011 08:00 PM
Rear wheel and tire size poloka 2011-2014 Mustang GT 11 07-27-2011 07:44 AM
06:13 PM
