Transmission Issues - Mustang Evolution
Old 12-15-2011, 01:15 PM   #1
Sycopath80's Avatar
Transmission Issues
I'm having issues with my automatic tranny not catching, its getting the power from the motor but it lags and feels like its starting in second, but its in first. So I got told to drop the granny pan and get new filter and gasket with tranny fluid. If I do that, should I mess with the torque-converter or leave it alone?
Sycopath80 is offline   Reply With Quote
Old 12-21-2011, 10:05 PM   #2
Mr. SoloDolo's Avatar
How many miles does your stang have on it?
Mr. SoloDolo is offline   Reply With Quote
Old 12-21-2011, 10:51 PM   #3
Re: Transmission Issues
leave the converter alone for now...just do a service change...you can pick up a filter kit at any autoparts store for around $15 for the most part....it includes the new gasket as well...change the fluid and see how that does....and after you drain it take a good magnet over the old fluid and look for metal shavings...if you find a good amount you have probly sheared something, and will need to get it fixed
SonicBoom239 is offline   Reply With Quote
Old 12-22-2011, 11:45 AM   #4
Changing our transmission fluid is not that simple since we don't have a dipstick I don't know how to refill it with new fluid any suggestions?
Old 12-27-2011, 09:15 PM   #5
JimC's Avatar
The drain plug is a two piece plug, you undo the entire plug to drain the fluid. Then you need the tool:
Amazon.com: OTC 6604 Transmission Fluid Fill Adapter: Automotive
this goes in the center of the drain plug (there is a hex key headed insert) and you have to pump the fluid UP into the transmission. Once it starts to drain back, put the center insert back in and start the car - run it through the gears and get the transmission up to temp.
Then - leave the car running, in gear, and put your OTC tool back in and pump more fluid up until it starts to drain back again.
It can be done on jack stands, but it isn't easy and not something you really want to do with a car running over top of you while you are trying to move around on your back with limited space. So if you don't have a lift available you are better off biting the bullet and having it done at the dealership (most transmission shops and oil change places can't do the sealed Ford 5R55 transmission).
JimC is offline   Reply With Quote
Old 12-28-2011, 12:36 AM   #6
Wow thanks man very informative. Well I guess Fords the way for me!
Interior Issues? Dion11197 2011-2014 Mustang GT 20 12-05-2011 06:55 AM
Choosing a tranny? Hawk General Mustang Discussion 0 10-08-2011 07:41 PM
Misfire issues Ghostedmind Pre-2005 V6 Mustang 1 10-02-2011 12:52 AM
2011+ 5.0, lets have a poll on issues DDTCM 2011-2014 Mustang GT 36 09-14-2011 05:56 AM
Transmission problem carlgator 1979-1995 Mustang GT 1 08-14-2011 09:52 PM
12:40 PM
