How low, with 18 inch rims?? - Mustang Evolution
Old 12-23-2011, 09:34 PM   #1
tdurham19's Avatar
I have a 06 v6, when I bought the car it was used and it came with lowering springs. Currently I have 18 inch cobra rims on my car, with the springs. But the springs are beginning to squeak, A LOT. So I need to get new ones.
What would be my best bet, should I go with another set of after market springs, or get used stock springs?
tdurham19 is offline   Reply With Quote
Old 12-24-2011, 12:46 AM   #2
93slowstang's Avatar
Maybe you need check your shocks. Can't really see your springs squeaking unless there are no isolators.
---------- Post added at 01:46 AM ---------- Previous post was at 01:44 AM ----------
In other words you shouldn't need a new set of springs.
Old 12-24-2011, 10:15 AM   #3
tdurham19's Avatar
Your probably right it could be the shocks. But about a month ago I sprayed my springs with WD40 and the speaking stopped for about two days so I figured it was my springs
Old 12-24-2011, 11:52 AM   #4
tdurham19's Avatar
**squeaking
Old 12-24-2011, 12:11 PM   #5
DaBluedude's Avatar
Its not the springs, its the poly bushings. Gaurantee. Silicone spray will work a lot better on them. They really need to be regreased or you need to swap the bushings out for rubber ones. Its not the springs fault.
2003 Mach 1
Old 12-24-2011, 12:57 PM   #6
tdurham19's Avatar
How hard is it swap the brushing for new ones. I found some at summit racing for cheap, will I be able to do the swap myself?
---------- Post added at 02:57 PM ---------- Previous post was at 02:57 PM ----------
**bushing
Old 12-24-2011, 01:25 PM   #7
DaBluedude's Avatar
**bushing
Its not brain surgery but it is serious work. Involves removing the struts, tie rods, end links and having the.car way up in the air. The rear requires you to drop the lower control arms. If your not a bit of a car junkie your gonna need a shop. For now try some poly bushing grease and some silicone spray.
2003 Mach 1
Old 12-26-2011, 10:33 AM   #8
tdurham19's Avatar
Yea ill try the grease and spray for now.
Thanks for the help!
Roush rims Rapinator126 Roush Mustang 3 12-28-2011 08:43 AM
Biggest rims i can fit Redlsea 1996-2004 Mustang GT 6 11-14-2011 01:18 PM
Will 99 15" rims fit my 03 gt? loridee Mustang Wheels & Tires 3 11-04-2011 01:23 PM
I need rims 01StangGt 1996-2004 Mustang GT 7 10-10-2011 08:19 PM
put gt500 rims on my 2011 gt guzie 2011-2014 Mustang GT 13 09-02-2011 04:38 PM
» Members Mustangs
silvia
Smoke
virgina
emerson
Add your Mustang
09:17 PM
