Rear End Swap - Mustang Evolution
Old 12-30-2011, 02:37 AM   #1
Sycopath80's Avatar
Rear End Swap
I have a 2005 MUSTANG V6 and I bent one of my rear axles. So im going to just repalce the entire rear axle assembly. Can I buy a rear assembly of a GT with the 8.8 gears and replace the one I have now, without having to do a ton of extra work?
Sycopath80 is offline   Reply With Quote
Old 12-30-2011, 04:51 AM   #2
JimC's Avatar
Re: Rear End Swap
Easy to do and the simplest and cheapest overall upgrade. The 8.8 mounts up the same way as the 7.5, the only difference in the axle is the size of the differential housing. Just unbolt the 7.5 and then bolt in the 8.8.
You will need to get the cobra flange (about $20) for the pinion though so that the V6 driveshaft will mount to it. That is the most difficult part of the swap because getting the flange set up with the proper pre-load is critical. I took my 8.8 to a rear end shop and had them swap it for me so that I knew it was done right.
JimC is offline   Reply With Quote
Old 12-30-2011, 10:11 AM   #3
BDK
BDK's Avatar
Region: Alaska
Re: Rear End Swap
Ditto, really worth the cost a much better driver after I did it.
BDK is offline   Reply With Quote
Old 12-30-2011, 11:25 AM   #4
stampde's Avatar
Re: Rear End Swap
+1
2011 GT Auto
Rear end clunk Brad.krieg SVT Mustang 3 12-08-2011 12:05 AM
rear end said, "F&$k it!" rinfield2004 SVT Mustang 8 11-18-2011 12:30 PM
95 8.8 5Lug Rear End into 87 5.0 Fox mcdonaldnick 1979-1995 Mustang GT 2 10-12-2011 06:03 PM
Rear end swap bmabbott Pre-2005 V6 Mustang 9 10-01-2011 12:14 AM
Rear end BigSteve305 Pre-2005 V6 Mustang 5 08-15-2011 09:25 AM
08:52 PM
