Swapping a 4.6 into a 2006 V6 - Mustang Evolution
Old 01-01-2012, 08:49 AM   #1
DAG 01's Avatar
What does everyone think of swapping a 4.6 into my 2006 V6?
DAG 01 is offline   Reply With Quote
Old 01-01-2012, 11:16 AM   #2
kickerofdoom's Avatar
Always the same easier to buy the car. Also they say if you are going to swap go for the best possible like a 5.4 engine or something
Old 01-01-2012, 01:51 PM   #3
saxxx's Avatar
Yea build a good motor and go all out ... You could turbo your car a nd make close to 5o0 hp
saxxx is offline   Reply With Quote
Old 01-01-2012, 01:58 PM   #4
Just enjoy what you have read and search and you learn a lot of what you have
Old 01-01-2012, 02:27 PM   #5
DAG 01's Avatar
Re: Swapping a 4.6 into a 2006 V6
Where I work I can get a deal on a 4.6 with a 5-speed out of a rolled 05 GT, as well as cheaper parts and a discount on the labor of doing the swap. Anyone have a rough estimate of the cost of all the necessary parts needed to do the swap, aside from the cost of the motor and trans?
Old 01-01-2012, 09:49 PM   #6
Well you need fuel,plus the 8.8 rear end,motor mounts,different exhaust
Old 01-02-2012, 08:21 AM   #7
JimC's Avatar
If you have a donor car it makes the swap a lot easier; even easier if it is coming from the same model year. No need to change the fuel pumps or motor mounts, everything is the same there. Get the 8.8 rear end, the 7.5 won't last.
You will need the computer from the donor car and a tune that disables PATS because things won't match up. There are miscellaneous bits and pieces you will need as well - most of which can be pulled from the donor car.
Several people over at mustangcollective.com have done the swap and there are some write ups on what you will need there.
JimC is offline   Reply With Quote
Choosing a V6 over a V8 Shidifen 2005-2010 V6 Mustang 57 12-02-2011 05:19 AM
V6 K-members same as 4.6? Otlaw80 Pre-2005 V6 Mustang 7 10-21-2011 11:27 AM
2011 V6 versus 2012 GT 5.0 avengnd General Mustang Discussion 6 09-01-2011 04:49 AM
2006 GT Stock Bullit 17x8 -> 2002 Mustang v6 FghtinIrshNvrDi Mustang Wheels & Tires 6 06-27-2011 09:29 AM
11:05 PM
