American muscle - Mustang Evolution
Old 01-04-2012, 03:36 PM   #1
Devil5711's Avatar
American muscle
Any one seen the American muscle project car. Their running nitroious on it. If I were to run nitrious what would I need should I make any additional changes to the car
Devil5711 is offline   Reply With Quote
Old 01-04-2012, 06:11 PM   #2
JimC's Avatar
Re: American muscle
Get the Zex wet kit - you want a wet kit (it adds fuel as well as nitrous through one inlet). The kit is fairly complete, but for safety get the Zex window switch as well and don't rely upon the Zex "nitrous management unit" (NMU) to keep you from spraying too low. The NMU is supposed to learn when you are at wide open throttle and keep it from spraying, but it will read WOT very low I found out (was getting staged one night and had the system armed, brought the RPM up to 1700 or so and was bumping into the beams when the NMU read me as WOT and fired off).
The window switch lets you set an rpm window for when the NMU will "see" the rpm signal and it won't let the system read too low, plus it will shut off at whatever upper limit you choose, so if you have a stick and miss shift it doesn't rev up too high while the juice is flowing.
Get a pressure gauge for the bottle and a tune for the car as well.
Depending upon where you live you may need a heater. Here in Michigan when I was running a 75 shot of nitrous in the spring and fall, and the cool summer evenings I needed the heater to keep the pressure up. A purge is nice, but not required. It does let you get fresh nitrous up to the inlet though after you do your burnout and while in pre-stage.
Nitrous is a lot of fun, but it is a track only power adder. It costs about $4 a pound for nitrous fill in the 10 lb bottle, and on a 75 shot I could usually get 10 passes before pressure started dropping and performance fell off.
JimC is offline   Reply With Quote
Old 01-04-2012, 07:03 PM   #3
Devil5711's Avatar
Go to go greatly appreciate that
Visit to American Muscle SLDGT500 AmericanMuscle 14 11-01-2011 05:52 PM
American muscle show 5.slow Regional Mustang Discussion 10 08-21-2011 07:02 PM
American muscle show 04machazblue 1996-2004 Mustang GT 1 08-21-2011 11:01 AM
American muscle car show 04machazblue 1996-2004 Mustang GT 38 08-20-2011 07:58 PM
Sct from american muscle nickysixx 2005-2010 Mustang GT 10 06-25-2011 06:33 PM
01:32 AM
