Nos on a 4.0 - Mustang Evolution
Old 01-11-2012, 08:36 PM   #1
IsaacT01's Avatar
Nos on a 4.0
I have a 2009 mustang 4.0 I was considering adding nos to it. But my only problem was how big a shot do I want to go with any suggestions?
IsaacT01 is offline   Reply With Quote
Old 01-11-2012, 09:49 PM   #2
soccerfreak2143's Avatar
Not entirely sure, but i think its like 75 at the most with a really good tune. If youre worried about breaking stuff, it might be safer to go smaller. But a good tune cant be stressed enough...its a must
soccerfreak2143 is offline   Reply With Quote
Old 01-12-2012, 08:59 AM   #3
Beau's Avatar
IMO if your willing to drop that much on NO2 make sure you have other mods first. Seems almost pointless to do if you have none other. Not saying you don't but just a good factor to consider. And nos is a brand... NO2 is nitrous
Beau is offline   Reply With Quote
Old 01-12-2012, 09:16 AM   #4
IsaacT01's Avatar
Thanks for the advice on doing other mods to the motor first. And on the nos correction
Old 01-12-2012, 10:03 AM   #5
Beau's Avatar
Yeah you won't feel any difference unless your letting out the NO2. So it makes it a expensive mod for a few seconds. Plus with other mods it'll help the CO2 breathe and add more!
Old 01-12-2012, 12:40 PM   #6
Mr. SoloDolo's Avatar
Not to mention you're gonna have to upgrade to an 8.8 GT rear axle, better brakes, handling and suspension needs to be changed and lowered for safe handling at high speeds and to play it safe I would get a stronger lighter carbon fiber or aluminum drive shaft
Mr. SoloDolo is offline   Reply With Quote
Old 01-12-2012, 06:53 PM   #7
JimC's Avatar
Re: Nos on a 4.0
Nitrous is a track only power adder - not street friendly, and it would be VERY expensive to run on the street anyway. So if you are planning to put it on your car I assume you will be going to the drag strip. Nitrous isn't for a road course, it is a quick power adder for the 1/4 mile so no need to lower the car like someone said - you aren't all that worried about handling in a straight line. The stock driveshaft will be fine too - you won't exceed the tolerance in the 1/4 mile - but the aluminum driveshaft is a good mod anyway.
You will need the 8.8 and tlok, otherwise you won't get the power to the ground, and you will break the 7.5 before long with the torque of the nitrous. Also upgrade the lower control arms on the rear end.
A 75 shot is safe, people have gone to the 100 but when I had it my tuner (Lidio at Alternative Auto) didn't recommend going any higher.
As far as engine mods, the 4.0 can handle it fine - with a proper tune. Brakes will be fine too, no need for different set up there. By the time you get through the traps you will be lifting and coasting and the car will be operating as naturally aspirated so no different than stopping from any speed.
The Zex kit that I had was very easy to install. Get a window switch though - don't rely upon the kit learning wide open throttle, it will fire off very low in the RPM and that is "bad." Set the window switch so it blocks the tach signal from your nitrous controller until you pass at least 2,300 rpm - if you have a stick you want the upper limit set so that when you shift, or miss a shift, you don't over rev too.
Here's some comparison dyno sheets. The torque of nitrous is amazing, I always enjoyed it, just got tired of filling up the bottle every track visit and got a great deal on my supercharger.
With just a C&L and tune
With a 75 shot of nitrous
JimC is offline   Reply With Quote
Old 01-12-2012, 09:36 PM   #8
IsaacT01's Avatar
Is the 8.8 important cause I was planning to do install a t-lok along with 3:73 gears .
Old 01-13-2012, 04:27 AM   #9
JimC's Avatar
Re: Nos on a 4.0
Worst modding decision I ever made was trying to build the 7.5 up and putting in the tlok, 3.73's and the LPW girdle. It was more expensive than the 8.8 I ended up swapping in, and I still broke it with just a CAI and a set of drag radials. Nitrous would have blown it up worse - I had the nitrous 75% installed (hadn't tapped the intake yet or finished the wiring) and if I had the nitrous with that big torque hit it would have blown up even worse.
Look at the dyno sheet and how quickly the torque hits - nitrous is immediate and not linear like other power adders.
Old 01-13-2012, 07:02 AM   #10
IsaacT01's Avatar
Dude the torque shot up like that's amazing. I'm have to get me a bottle soon.
adding NOS to my supercharged motor Sirtat 2005-2010 Mustang GT 5 01-09-2012 07:11 PM
3.8 to 4.0 98projectpony Pre-2005 V6 Mustang 7 01-04-2012 10:36 AM
What are the best headrrs for a 07 v6 4.0 Ibhim919 2005-2010 V6 Mustang 7 01-03-2012 02:13 AM
3.8 v6 - 4.0 v6 mustangg2000 Pre-2005 V6 Mustang 8 11-22-2011 12:38 PM
Nos wet or dry? Z06 eater 1979-1995 Mustang GT 3 07-03-2011 10:01 AM
04:46 AM
