Completely Lost!!! - Mustang Evolution
Old 01-12-2012, 06:01 PM   #1
Mr. SoloDolo's Avatar
Completely Lost!!!
So my pony has about 70,000 miles on it and recently I've noticed that she's become a little slugish any idea what could be causing this?? Also she an auto 6 shooter.
Mr. SoloDolo is offline   Reply With Quote
Old 01-12-2012, 06:35 PM   #2
Clean your air filter change ur oil and flush and fill ur trans and diff if the problem still persists check ur plugs and get new or regap old as needed also change ur fuel filter and put in some fuel system cleaner thats the basics and theres more u can do "mantaince wise" that can help but start there and see how it goes.
Hawk is offline   Reply With Quote
Old 01-12-2012, 06:53 PM   #3
Eturner's Avatar
+11
Old 01-12-2012, 06:56 PM   #4
JimC's Avatar
Re: Completely Lost!!!
When did you last change your fuel filter?
JimC is offline   Reply With Quote
Old 01-12-2012, 07:23 PM   #5
Ok I just changed my fuel filter about three months ago or so new royal purple just put in new air filter new plugs and I just sea foamed it. But I never have had a transmission fluid flush and rear gears have never been relubed. So I guess I can do those things any idea on where I can get these jobs done ..I'm pretty mechanically inclined also
Old 01-12-2012, 07:30 PM   #6
bobbytheapple's Avatar
hmm this is interesting. I've never dealt with my transmission or gears either.
bobbytheapple is offline   Reply With Quote
Old 01-12-2012, 07:52 PM   #7
JimC's Avatar
Transmission you need to go the dealer. It requires a lot more than they used to. It can be done, but if you don't have access to a lift it is a real problem. You have to drain the transmission, then there is a tool you insert into the center section of the drain plug to pump fluid back up into the transmission. Then you have to run the car to get the transmission up to operating temperature so you can fill it the rest of the way - and the best way to fill it that second time is with the car running and in gear, not something I want to do with the car on jackstands in the driveway and me laying on my back underneath it.
Most transmission shops and quick lube places can't do the Ford sealed transmission. (no dipstick to fill or check the fluid level)
Myths about "back-pressure" Eturner General Mustang Discussion 45 09-08-2016 01:31 PM
Occasional hesitation I'm lost. shade tree 1996-2004 Mustang GT 7 12-02-2011 06:39 AM
Clutch... Lost Gigerdavid 1996-2004 Mustang GT 19 11-14-2011 09:17 PM
Lost on what's wrong with my 'stang SCenteno112 Pre-2005 V6 Mustang 9 10-08-2011 10:24 PM
i lost the lug nut key!!!!!!! secomejia General Mustang Discussion 23 08-18-2011 08:30 PM
11:18 PM
