Next purchase HELP! - Mustang Evolution
Old 02-05-2012, 06:17 PM   #1
jamin22786's Avatar
Region: Iowa
Next purchase HELP!
What's the best thing to purchase with a max $1000. I've got a bama tuner, C&L CAI, Zex Nitrous, axle back borla, headers, screamin' demon coil, and plug wires.
Right now I'm split between 70mm throttle body, 7.5" ford racing traction lock and 3.73 gears, a suspension system like the eibach sport system plus or ford racing power pack, and bigger/slicker rear tires/rims.
jamin22786 is offline   Reply With Quote
Old 02-05-2012, 06:21 PM   #2
saxxx's Avatar
Since you have nitrous id say throttle body and and the suspension kit... Then I'd gear it up with a tlok last... And to a 3:55 because ur spraying .. with 3:73s your top end would be cut down and when you spray your wheels would prob just spin being such a steep gear ratio.
saxxx is offline   Reply With Quote
Old 02-05-2012, 08:18 PM   #3
JimC's Avatar
Re: Next purchase HELP!
With nitrous you will be blowing up the 7.5 in a short time - don't try to build it up, it will not handle the torque. Just get an 8.8 and swap it in. That will be cheaper than buying a t-lok, gears, and paying to have it all installed than the 8.8 will cost.
Worst modding decision I ever made was trying to build the 7.5. I broke it with just a CAI and set of drag radials; hadn't run a shot of nitrous through it before I broke it.
If you don't have a window switch for your Zex that is the next thing to get, the Zex NMU will read WOT at very low rpm (also learned through experience, lucky for me I lifted as soon as it fired off at 1,000 rpm).
Also, don't bother with the throttle body, even with a power adder they don't do much and some of them will cause you problems.
JimC is offline   Reply With Quote
Old 02-05-2012, 08:35 PM   #4
saxxx's Avatar
Agree about the 8.8
Rear after first AM purchase Bryangb7 1996-2004 Mustang GT 1 01-30-2012 02:38 PM
First AM Purchase, Not so good.. MiGT01 AmericanMuscle 41 01-29-2012 06:16 AM
Another AM purchase avengnd 2011-2014 Mustang GT 16 01-25-2012 04:47 PM
What is the best cold air intake to purchase without a tune for a 2008 4.0 v-6? Since64 2005-2010 V6 Mustang 9 01-19-2012 10:21 AM
New purchase.. mazayu 1996-2004 Mustang GT 17 09-25-2011 04:08 PM
05:07 PM
