p0193 engine code - Mustang Evolution
Old 02-07-2012, 03:01 PM   #1
usmc.Cavanaugh's Avatar
p0193 engine code
I got.that as my engine code I can't figure how to.fix it it says pressure sensor so.I was told to try changing the fuel filter did that came back on any ideas please thanks!
usmc.Cavanaugh is offline   Reply With Quote
Old 02-07-2012, 04:29 PM   #2
Cobrarunnin9s's Avatar
Re: p0193 engine code
Try checking the fuel rail pressure sensor.
Cobrarunnin9s is offline   Reply With Quote
Old 02-07-2012, 04:36 PM   #3
irishn8's Avatar
there are two paths to go from here and I recomend getting a fuel pressure gauge if ur the D.I.Y. type and make sure your fuel pressue is in specification. If that is fine then you know its the sensor. Also you can test the sensor, expected voltages are between 4 and 6 volts I believe. The other path of course is just replacing the fuel filter since that's a maintenance item anyway, but if that doesn't fix it then get a new sensor and if that still doesn't fix it then we start troubleshooting the fuel pump.
Old 02-12-2012, 07:29 PM   #4
Thanks guys I replaced the pressure sensor and it works great lights off I appriciate the help
Old 02-12-2012, 08:28 PM   #5
No problem, glad it worked.
« wheels | 2005 V6 »
Myths about "back-pressure" Eturner General Mustang Discussion 45 09-08-2016 01:31 PM
selling a 1989 4 cylinder mustang with a 5.0 engine and transmission both working 1987mustanglx50 2.3 Mustang 0 01-25-2012 01:30 PM
engine code 82stang30 1979-1995 Mustang GT 5 12-28-2011 09:04 PM
99-04 Mustang GT ENGINE BLOWN!!! HELP!!! FORDGT14 1996-2004 Mustang GT 17 09-16-2011 02:11 PM
having trouble help check engine light keeps coming on for the same code mustangsally696 General Car Discussion 2 08-18-2011 07:02 AM
07:50 PM
