Creaking & sloppy steering - Mustang Evolution
Old 02-10-2012, 05:10 PM   #1
wheelman's Avatar
Trading in my '07 V6 in a few months, but still need to fix a few things before I do. Doesn't need to be perfect, but I don't want it to fall apart like a Blues Brothers scene in the dealer parking lot either.
I've had this creaking going on that I'm not sure the source of. I got some rain water in my car a few times and I noticed a little rusting under the seat, so I thought that was the source of the creaking in the seat. I redid the seat covers though and when I did, I lubed up all the moving parts and repainted the rusted parts. Later, I realized that it was much more pronounced when the car moves around at all (like if I'm shifting around in the seat) while parked on a hill. So I'm now realizing it's coming from the suspension somewhere. Not sure where and what to look for exactly, so any direction would be appreciated.
Strangely, I also have creaking in the brake pedal, which is why I first thought all the creaking was from rain water rusting. I lubed what I could, but soon realized, as the noise increased, that it's only when the brake is fully depressed, so it's not the movement of the pedal itself. When it first started, I just thought it was related to brakes and had them looked at when I had my car at the dealer for service. They said I still had life left on the pads and I didn't question it further at the time because it wasn't too bad. 6 months later it's pretty loud. Might need new pads by now, but there's obviously another issue because it's not a low pad/grinding rotors type a sound. It's a creaking when the pedal is depressed.
And finally, steering is getting pretty sloppy. I recently replaced a LCA and the tires are in pretty good shape. What're the most likely culprits?
Thanks for any ideas ya'll got.
wheelman is offline   Reply With Quote
Old 02-16-2012, 12:18 AM   #2
saxxx's Avatar
I know this is off topic bit are you trading your v6 for a gt
saxxx is offline   Reply With Quote
Old 02-16-2012, 12:37 AM   #3
irishn8's Avatar
How I troubleshoot these problems is I have someone re-create the symptom while I locate it. Have someone turn the stearing wheel back and forth while you follow every moving part all the way through untill u see what isn't moving as much as it should. Have someone recreate the noises while you follow all the moving parts, joints, and linkages listening for the sound. You can even feel the creaking the best at its source. Works for me every time, good luck!
Old 02-16-2012, 09:54 AM   #4
wheelman's Avatar
Re: Creaking & sloppy steering
Good idea. Have a dealer appt tomorrow but at least want to identify the problem first & may fix myself so will do; thanks.
Old 02-16-2012, 12:31 PM   #5
irishn8's Avatar
Very good! Always good to know what's wrong before you go to a mechanic especially if ur not under warantee.
1964 nto 2008 steering wheel grumpyjk 2005-2010 Mustang GT 1 12-14-2011 04:52 PM
Power Steering Pump NYmustang5 Pre-2005 V6 Mustang 5 11-14-2011 02:24 AM
Steering decision help Rockn69Stang Classic Mustangs 2 10-31-2011 07:14 PM
Ditching power steering? Stang.racr 1979-1995 Mustang GT 4 08-24-2011 03:36 PM
Steering rack. 5.slow 1979-1995 Mustang GT 2 08-19-2011 02:36 PM
07:25 PM
