NEED HELP ASAP!!!!!!!!!!!! - Mustang Evolution
Old 02-26-2012, 11:53 AM   #1
Blogger
99ford's Avatar
I'm desperate and in need of lots of help! I've got a stuck a bolt without a head! Anyone know to fix the problem??
This bolt attaches to the throttle body. See the image below:
Thank-you in advance!
Attachment 41881
Old 02-26-2012, 12:16 PM   #2
Blogger
99ford's Avatar
Re: NEED HELP ASAP!!!!!!!!!!!!
Any suggestions? I'm desperate. So far I've heated it up and turned with pliers.
Old 02-26-2012, 12:21 PM   #3
Eturner's Avatar
Vice Gripes?... I've heard of ways to cut the remainder off then drill and tap!.. But I've never had to do that before so I don't know!..
Maybe use two Vice Gripes on it!..
Old 02-26-2012, 12:28 PM   #4
DaBluedude's Avatar
File two sides down and use pliers or vice grips.
2003 Mach 1
Old 02-26-2012, 12:36 PM   #5
deadsp0t's Avatar
I can't get the pic to load but you have some options.
If any of it is sticking out you can soak in penetrating lube like sea foam and try to use Vise-Gips to turn it out.
You can drill a small pilot hole and try an extractor/ez out bit(be careful as they break ez)
You can just drill straight through it.
You can weld something to it to turn it out.
That's unimpressive
Old 02-26-2012, 05:47 PM   #6
jamin22786's Avatar
Region: Iowa
you could file what's left down to the shape of a hex bolt then use a wrench or impact wrench but you won't have a very big head to work with. Just make sure you use a lot of penetrating oil before you try to get it off. If you don't fix the seizing issue, you will continue to snap the bolt, you're lucky you still have enough bolt remain to weld to
jamin22786 is offline   Reply With Quote
Old 02-26-2012, 06:04 PM   #7
deadsp0t's Avatar
An old pipe fitter told me once if you can't tighten it you can't break it loose.
That's unimpressive
Old 02-26-2012, 06:48 PM   #8
Blogger
99ford's Avatar
Thanks for the suggestions! I went back to home depot and bought 2 sets of vise grips a soldering iron, a heat gun, and bolt off. Finally got it! They used some blue stuff to secure it in place.
It took all day today, and half of yesterday. Everything is back in place now yay!
Old 02-26-2012, 06:53 PM   #9
deadsp0t's Avatar
The blue stuff is blue loc tite, usually not that hard to get loose. When you replace the bolt I'd suggest using green loc tite, which isn't quite as strong, just make sure everything is clean. glad you got it off!
That's unimpressive
Old 02-26-2012, 07:00 PM   #10
Eturner's Avatar
A bolt on the TB shouldn't need any loc tite!..
Old 02-26-2012, 07:04 PM   #11
deadsp0t's Avatar
Mmmm I respectfully disagree.. I put blue on almost everything, and never had any issues and blue's stronger then green. For me it comes down to better safe then sorry, over the years I've seen all types of bolts that shouldn't need loc tite end up needing it.
That's unimpressive
Old 02-26-2012, 07:21 PM   #12
jamin22786's Avatar
Region: Iowa
congrats! i had an oil filter get stuck on one time, ripped it clear off and ended up having to take the housing off to remove, worst mustang day ever, never let somebody else touch the stang again!
Old 02-26-2012, 07:24 PM   #13
deadsp0t's Avatar
Oil filters should only be hand tight lol
That's unimpressive
Old 02-26-2012, 07:28 PM   #14
jamin22786's Avatar
Region: Iowa
Congrats! You're more qualified to change oil than a certain mechanic!
Old 02-26-2012, 07:31 PM   #15
deadsp0t's Avatar
I don't work on cars to often but I make a decent living turning wrenches proving it doesn't take a genius lol
That's unimpressive
Old 02-26-2012, 07:48 PM   #16
Blogger
99ford's Avatar
Thanks I completely feel your pain! I was like this should be easy maybe a 2 hour job, i only had two things to do. 1.Clean throttle body-check. That took 30mins total. 2 Replace throttle position sensor- install new ( at this point I was like another 2 hours tops the directions were straight forward). The bolts were so tight. And to top things off, I stripped the bolt for the battery terminal- i should've stopped and came back. I just want to forget today ever happened what a nightmare! I'm sure you felt that way after you finished.
---------- Post added at 09:48 PM ---------- Previous post was at 09:40 PM ----------
That's what Ford put on it, from what I read on the internet they've been making them that way since at least 94. Loc tite locks tight lol! The throttle body alone doesn't have anything on those bolts. But w/o loc tite, it wouldn't stay put those are open holes on the end.
Just to clarify I won't take this off again! It will be the next guys problem.
Old 02-26-2012, 08:03 PM   #17
Eturner's Avatar
I replaced my TB about five years ago and didn't use any loc tite on it and had zero problems!.. There really is no good reason to use loc tite on those bolts!.. There is no amount of torque, tension, or vibration going through them to justify using loc tite!.. And clearly what happened to the OP is case and point!..
And ya I don't let just anyone touch my cars either!.. Just because some one works as a mechanic doesn't mean they know what they are doing!.. Back when me and my wife were still dating I thought I would do the nice thing, and change the oil in her car for her!.. The last time her oil was changed was about a year earlier, and was done by a small shop that her whole family uses!.. Took me about a day to get the drain plug off!.. Come to find out the idiot put it on with a F***ing impact wrench!..
Old 02-26-2012, 08:18 PM   #18
deadsp0t's Avatar
If you take a second to look, the man said it came that way from Ford. Any way my exp has always been better safe then sorry and if you don't want to do it right the first time you won't like doing it twice, and it's attached to the engine, it's hot and vibrating constantly. Right?
That's unimpressive
Old 02-26-2012, 08:33 PM   #19
Eturner's Avatar
Yes I saw that he said it came from the factory like that!.. Just because it came that way from the factory don't mean it's the best idea either!.. Plus if you take a look at what I was saying!.. There is no vibration going directly through your TB bolts!.. Loc tite isn't needed there!.. He'll I replaced the TB on my '96 Monte and there was no loc tite put on those bolts by the factory nore by me!.. And still had zero problems!.. Not to mention that when I replaced the TB on my Mustang it had no loc tite on it either!.. Clearly loc tite is not needed on TB bolts!..
Now if your talking about things like head bolts!.. Then he'll ya loc tite those B****s!!... Lol. They are much closer and directly related to the source of your vibration!.. If those loosen up then your looking at some major problems!..
Old 02-26-2012, 08:42 PM   #20
deadsp0t's Avatar
I think I'll leave the engineering to the engineers………
That's unimpressive
Old 02-26-2012, 08:45 PM   #21
jamin22786's Avatar
Region: Iowa
so we all agree to meet in the middle, green loc-tite! now everybody hug!
Old 02-26-2012, 08:49 PM   #22
Eturner's Avatar
True!.. But like I said, just because that's they way they designed it doesn't mean it was the best way!..
The way the alternator was placed on my Monte was idiotic at best!.. You either had to pull the engine, or completely rip out the passenger side wheel assembly to get the alternator off!.. Engineers designed that!.. Lol. Not me!..
Old 02-26-2012, 08:53 PM   #23
jamin22786's Avatar
Region: Iowa
My wife has a buick that requires removing the engine to replace spark plugs...
Old 02-26-2012, 08:53 PM   #24
deadsp0t's Avatar
wow……it's a Chevy………seriously……the loc tite and other thread lockers are there for a reason………to insure that they NEVER come loose w/o help……
That's unimpressive
Old 02-26-2012, 08:57 PM   #25
deadsp0t's Avatar
Yet another GM product.....smh
That's unimpressive
Old 02-26-2012, 09:05 PM   #26
Eturner's Avatar
My dad had a Buick that had a plastic timing gear!.. Lol. I only had to remove the the ignition coils and the entire intake, to include the the plenum, to replace the back three plugs!.. Lol. Thing was a complete B**** to work on but it was still a ton of fun to drive!.. I still kinda miss that car!..
HELP!!!!! jacob.a.gasparp 1979-1995 Mustang GT 41 04-29-2012 07:07 PM
Plasti Dip Help! BeasGT 1996-2004 Mustang GT 33 02-27-2012 11:34 AM
98 3.8 in need of power.. cam? trixinahat Pre-2005 V6 Mustang 33 02-26-2012 08:40 PM
Help from the 6er community!! 2002VertGT Pre-2005 V6 Mustang 13 02-26-2012 05:39 PM
help! jstn_hasty 1996-2004 Mustang GT 6 02-26-2012 01:47 AM
08:58 PM
