Overdrive and Tuners - Mustang Evolution
Old 03-02-2012, 09:50 PM   #1
So I am about to buy a tuner! It'd help with gas prices, which is a big feature for me. A few questions though...
First: Is the overdirve for the mustang always on when you start the car? Because mine is, and I have to turn it off otherwise I wast more gas than I should.
Second: Is there a way I could keep the over drive off? And turn it on when I want?
Third: With the tuner, could I change the way the overdrive runs? For example... Have the overdrive be the power mode, and overdrive off would be gas saver for me. If that makes sense... Thanks guys!
horsin_around is offline   Reply With Quote
Old 03-02-2012, 10:07 PM   #2
Re: Overdrive and Tuners
Your overdrive should be on when you start the car, so there will be no light or indicator on the dash. The O/D button will turn it "off" which locks out that overdrive gear, which will decrease your mileage and cause your engine to run at higher rpms, especially at higher speeds.
I'm assuming the 05+ work the same as the 99-04's which is what I have.
When I added a new shifter knob and boot etc I had to relocate the O/D button. The first time I relocated the button I installed the wires backwards, so the O/D would be "off" when I started the car lol. I simply switched them and it worked just like it did before when it was on the shifter knob.
Not sure whether the tuner would be able to adjust the overdrive settings, but that's a good question..the tuning service would probably know.
Old 03-02-2012, 10:53 PM   #3
So...is the overdrive actually better for my car? Since the rpm is lower?
Don't know anything about wiring..I should learn. Well, you knocked down 2 of my questions! Thanks a lot
gonna order my tuner tomorrow!
Old 03-02-2012, 11:41 PM   #4
Overdrive is pretty much the final gear in automatics... Your car will want to change to this gear as much as it can because it makes the engine run at lower rpm's which makes the engine run less and save gas... So you pretty much want to keep it on at all times. The only time people take it off is when in a truck pulling heavy loads because it will constantly go between o/d and the next highest gear which will (over time) damage your transmission.
Old 03-03-2012, 09:30 AM   #5
Mr. SoloDolo's Avatar
That sucks cause to me driving my car with the over drive off is alot more fun. My car respond faster and any time you press the gas it just picks up and goes effortlessly.
Mr. SoloDolo is offline   Reply With Quote
Old 03-03-2012, 09:58 PM   #6
That's what should happen when o/d is off... When you go full throttle the computer will automatically go from o/d into a lower gear to provide for better acceleration... o/d is basically for better engine/fuel efficiency.
Old 03-04-2012, 08:47 AM   #7
Wow, I have completely misunderstood the o/d....
Atlanta area and Georgia members roll call 99ford Regional Mustang Discussion 355 09-24-2014 09:24 AM
intake and carb dreamstang Mustang Parts for Sale and Wanted 9 04-05-2012 04:55 PM
My thoughts on my new SCT Tuner and CAI Project Pony Pre-2005 V6 Mustang 10 03-02-2012 04:56 PM
ATTN: Austin,San Antonio,Dallas and surrounding areas.....don't miss out! DDTCM Regional Mustang Discussion 23 03-02-2012 02:16 PM
autobots and deceptacons svtlx The Bar 1 03-02-2012 11:55 AM
09:04 AM
