5.4 swap - Mustang Evolution
Old 03-10-2012, 11:03 AM   #1
saxxx's Avatar
5.4 swap
Anyone here have any info .. I am thinking about going to the junk yard and getting one and building a sick street/track car
saxxx is offline   Reply With Quote
Old 03-10-2012, 08:54 PM   #2
angelofrat42's Avatar
Re: 5.4 swap
if you want to do this, you will have to get a 8.8 rear end because your 7.5 rear end cannot handle the power, you have to get a new transmission, new computer and wiring, new gears, and custom install. this would be an incredibly difficult and expensive but as long as you do everything to be safe and not have your car rip itself apart then you should be ok. oh and youll need a new suspension
angelofrat42 is offline   Reply With Quote
Old 03-11-2012, 01:21 PM   #3
Davey4.0's Avatar
Region: Nevada
More trouble and money than it would be work.I'd spend that money on a supercharged or turbo.would be fun to do the swap tho :p
Davey4.0 is offline   Reply With Quote
Old 03-11-2012, 06:45 PM   #4
saxxx's Avatar
Yea Ive hit a wall in mods... Idk weather to stop and save for a new car or mod the crap of my 4.0
Old 03-11-2012, 07:31 PM   #5
Davey4.0's Avatar
Region: Nevada
What mods do you have?
Old 03-11-2012, 09:54 PM   #6
saxxx's Avatar
Cai, exhaust
---------- Post added at 09:54 PM ---------- Previous post was at 09:53 PM ----------
Short throw Shifter
Old 03-11-2012, 09:57 PM   #7
Re: 5.4 swap
Cai, exhaust
Short throw Shifter
you hit a wall after just getting those?
headers, custom mid pipe, underdrive pulleys, throttle body, suspension (lowering kits, sway bars, struts, shocks), spark plugs, coil pack, injectors, oil separator, gears, tuner. man theres so much more you can get done before hitting that kind of wall and that doesn't include forced induction (turbo or supercharger)
Old 03-11-2012, 10:03 PM   #8
saxxx's Avatar
I just kinda wanna get something faster or some mod that's gonna give me like crazy good results that I can feel or see every time I get ready to drive
Old 03-11-2012, 10:10 PM   #9
Davey4.0's Avatar
Region: Nevada
Turbo
Old 03-11-2012, 10:43 PM   #10
afree05's Avatar
get yourself a tuner.
afree05 is offline   Reply With Quote
Old 03-12-2012, 12:32 AM   #11
Re: 5.4 swap
if you want something like that then get a turbo (though it will only give you more high rpm power) or a supercharger. i would suggest the x charger supercharger from americanmuscle.com it adds 140hp and 120 ft lbs of torque. itll cost you an arm and a leg but itll give you the most power without having to rebuild your rear end.
Old 03-12-2012, 02:41 PM   #12
saxxx's Avatar
I have a tuner ... And the turbo is a big investment just to have 400 hp
Old 03-12-2012, 05:04 PM   #13
45thMustang's Avatar
400 hp from a turbo or supercharger in a v6 can do quite bit cause its lighter. Look up the shelby terlingua mustang.
45thMustang is offline   Reply With Quote
Old 03-12-2012, 05:19 PM   #14
Re: 5.4 swap
what vehicle have you driven that has 400hp? cuz until you actually drive something with that much power then you wont know what its like. 400hp is a lot of power, more than enough for someone used to 200 with a v6 mustang. if you want more than that then just trade in for a gt and put a turbo on that or just twin turbo the v6. still 400 is more than you should need
Old 03-12-2012, 05:31 PM   #15
Las0mbra's Avatar
+1.... That's SVT Cobra HP.
Old 03-12-2012, 05:47 PM   #16
Re: 5.4 swap
not even, the cobra has 390 to the crank so maybe 335/340 to the tires
Old 03-12-2012, 05:48 PM   #17
deadsp0t's Avatar
A lot of termi's dyno'd 385 to the wheels right off the showroom floor.
That's unimpressive
Old 03-12-2012, 06:24 PM   #18
Re: 5.4 swap
regardless, 400hp is a lot of power, and if the only car youve ever driven consistently is a v6 mustang, your gonna be amazed at the difference
Old 03-12-2012, 06:36 PM   #19
Davey4.0's Avatar
Region: Nevada
400hp is more than you need for a everyday driver I have 290/310tq in my 4.0 and it has got me into some trouble, couldnt imagine 400.
Old 03-12-2012, 06:40 PM   #20
Las0mbra's Avatar
Well, some cobras dyno'd at 390-400ish stock... They were underrated from the factory.
Old 03-12-2012, 06:49 PM   #21
What mods have you done?
Old 03-12-2012, 07:47 PM   #22
JimC's Avatar
Re: 5.4 swap
actually as far as the rear end, any power adder you should upgrade to the 8.8. The 7.5 is an open differential so makes it more difficult to put the power to the ground. And if you try to build the 7.5 you will spend as much if not more than it costs to swap the 8.8 instead - and you still have a weak link in the 7.5 (I tried it, spent more to build it than the 8.8 cost me in the end, and still broke it with just a CAI, tune, and a set of drag radials).
With the Xcharger Xtreme I've even broken the spider gears in the 8.8 after running a set of cheater slicks for one race season.
The Xcharger Xtreme on my car - with a very fat and safe tune - is putting over 290 to the rear wheels. I'm waiting for a new tune right now that I expect will push more HP and torque to the rear wheels this season.
JimC is offline   Reply With Quote
Old 03-12-2012, 08:04 PM   #23
Davey4.0's Avatar
Region: Nevada
Stage 2 heads, underdrive pullies, fuel injectors stage 2 clutch,3.73 , T-lok, CAI,coil overs,spark plugs, aluminum driveshaft,tuner with 93 octane race tune,gt500 custom exhaust and a custom cat back. I've never had it professionally dyno's my numbers are estimated from my computer.give or take 10 ponies
Old 03-12-2012, 09:01 PM   #24
saxxx's Avatar
I've driven the boss 302 .. the only reason that i don't wNt to just trade it in is because its paid for! SO is it worth dumping loads of money in or should I just get something faster? And have a better foundation
Old 03-12-2012, 09:04 PM   #25
DaBluedude's Avatar
Trade it in...
2003 Mach 1
Old 03-13-2012, 12:32 AM   #26
deadsp0t's Avatar
Originally Posted by DaBluedude
Trade it in...
Agreed
That's unimpressive
Old 03-13-2012, 05:37 AM   #27
Where did you get the stage 2 heads and underdrive pulleys? I havent been able to find them.
Old 03-13-2012, 03:07 PM   #28
saxxx's Avatar
www.supersixmotorsports.com
Old 03-13-2012, 05:55 PM   #29
Davey4.0's Avatar
Region: Nevada
Supersixx.that's what I was about to say.my dad got me them for my 18th bday a while back.he had trouble finding them too.
head intake swap checklist 5.slow 1979-1995 Mustang GT 21 05-07-2012 08:02 PM
a couple more swap pics... svtlx 1979-1995 Mustang GT 30 03-07-2012 08:12 PM
a video of my mustang 5.4 build victory181 1996-2004 Mustang GT 6 03-06-2012 04:11 AM
a video of my mustang 5.4 build victory181 1979-1995 Mustang GT 2 03-05-2012 11:47 PM
Tranny swap 93 to 90 model auto Loudmustang 2.3 Mustang 3 03-05-2012 07:34 PM
08:03 PM
