Top Speed - Mustang Evolution
Old 03-13-2012, 11:08 PM   #1
Top Speed
Hey, I was just wondering what the top speed in an '05 V6 would be without the limiter? I want to find out for a comparison i'm doing.
Old 03-14-2012, 12:17 AM   #2
Davey4.0's Avatar
Region: Nevada
The limiter tops out at 114mph.the car wouldn't let you go over that without it being
Removed.I've topped mine one one time,and I still had plenty of throttle left in 5th gear. The engine componets are not made to go over the limited speed and removing the limiter and pushing this speed may damage your motor. If you built it up to withstand it could easily do over 130+mph.
Davey4.0 is offline   Reply With Quote
Old 03-14-2012, 04:50 AM   #3
StangRebel's Avatar
Re: Top Speed
Nicely put Davey, couldn't have said it better
StangRebel is offline   Reply With Quote
Old 03-14-2012, 05:05 AM   #4
ColeJohnson's Avatar
+1 limiters are in place on stock units for good reason.
2016 Comp Orange GT (current)
Old 03-14-2012, 07:53 AM   #5
Titus Wadicus
svtlx's Avatar
Re: Top Speed
does this include the 118mph catostrophic driveshaft failure.....
i guesse cole is right.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 03-14-2012, 08:23 AM   #6
I saw that video.. Scary stuff.
Old 03-14-2012, 08:33 AM   #7
Titus Wadicus
svtlx's Avatar
Re: Top Speed
i had the volume cranked up on my speakers and didnt realize it... scared the crap outa me.
it makes me feel like v6's are unsafe. like anything over 70-75 you are potentialy puttn ur life in ur own hands...
or maybe im just getn too old...lol.
hold on, while i tell those young whipper snappers to get off my lawn
Old 03-14-2012, 08:41 AM   #8
stampde's Avatar
Re: Top Speed
I've topped out the speedo on mine , lol
125-130 range ???
2011 GT Auto
Old 03-14-2012, 08:47 AM   #9
Titus Wadicus
svtlx's Avatar
Re: Top Speed
125-130 range ???
i think that applies to 05+ v6
so u should be fine i think and wont have to buy a new exhaust system when the drive shaft tells u to go get @#&$#@....
---------- Post added at 08:47 AM ---------- Previous post was at 08:46 AM ----------
just seen u got an 06... my bad. well i guesse it would givew u a good excuse to get sum long tubes...lol
---------- Post added at 08:47 AM ---------- Previous post was at 08:47 AM ----------
Old 03-14-2012, 08:54 AM   #10
stampde's Avatar
Re: Top Speed
YA MY V6 IS MY DD
The Mach 1's the toy
2011 GT Auto
Old 03-14-2012, 09:07 AM   #11
Titus Wadicus
svtlx's Avatar
Re: Top Speed
wut if we found out the driveshaft video was actualy made by a group of "rogue camero owners" from a competing forum...just to eff wit us...lol
Old 03-14-2012, 09:48 AM   #12
I know that the limiters are in place for a reason, i just want to know what it could actually put out.
Old 03-14-2012, 10:20 AM   #13
Beau's Avatar
Alls I know with my full exhaust and other goodies I've bent the needle pretty easily
Beau is offline   Reply With Quote
Old 03-14-2012, 05:53 PM   #14
08Mustang's Avatar
What all needs to be done after you apply a tuner to the engine so it doesn't damage it?
08Mustang is offline   Reply With Quote
Old 03-14-2012, 07:14 PM   #15
Beau's Avatar
A built engine pretty much for a 6. That's all I can think of
Old 03-14-2012, 08:30 PM   #16
08Mustang's Avatar
What ya mean built?
Old 03-14-2012, 08:33 PM   #17
Beau's Avatar
What ya mean built?
Not stock internals
Old 03-14-2012, 08:52 PM   #18
Davey4.0's Avatar
Region: Nevada
Just a stronger drive shaft and higher speed rated tires should let u go at least over 130 easily.anything over that I would ask a very skilled mechanic what you would need.the motor it's self has the capability of going 140-150mph, I've brought mine up to 114 in 5th gear and it wasn't even close to redline it was at mabey 3,000-3500RPM's
Old 03-14-2012, 09:06 PM   #19
08Mustang's Avatar
Yeah I've got performance pirellis but I can't find a high performance driveshaft the 05-09 v6 anymore!
---------- Post added at 10:06 PM ---------- Previous post was at 10:05 PM ----------
*anywhere...not anymore
Old 03-14-2012, 09:29 PM   #20
jamin22786's Avatar
Region: Iowa
I thought there were all kinds of aluminum shafts out there? I think am even had one?
jamin22786 is offline   Reply With Quote
Old 03-15-2012, 01:33 PM   #21
Davey4.0's Avatar
Region: Nevada
You would most likely have to pay LTL freight price to order one and ship it to your house.a one piece DS is to big for ups/fed ex
Old 03-15-2012, 01:47 PM   #22
08Mustang's Avatar
Nag AM only has an aluminum DS for the GT...but tell me if ya know one for the 05-09 v6
Old 03-15-2012, 03:24 PM   #23
jamin22786's Avatar
Region: Iowa
Sounds like a good reason to get the 8.8!
Old 03-15-2012, 11:11 PM   #24
08Mustang's Avatar
The gear?
Old 03-16-2012, 12:22 AM   #25
Beau's Avatar
Lol I don't think the rear end does much at top end... that's more for torque to me
Old 03-16-2012, 02:48 PM   #26
08Mustang's Avatar
Yeah a better transmission is for top end if ya have an automatic but rear end is for torque
Old 03-16-2012, 03:09 PM   #27
Beau's Avatar
And of course driveshaft lol
Old 03-16-2012, 04:06 PM   #28
08Mustang's Avatar
Yeah of course except I can't find one for my 08 v6!!
Old 03-16-2012, 04:11 PM   #29
Beau's Avatar
When I get home ill help ya search and if I find one ill shoot you the link
Old 03-16-2012, 10:23 PM   #30
jamin22786's Avatar
Region: Iowa
New rear end is to fit aluminum driveshaft
Old 03-18-2012, 12:51 PM   #31
StangRebel's Avatar
Re: Top Speed
Driveshaft's do make a big difference
86 mustang gt 5 speed loses power at high RPMs lilrafe87 1979-1995 Mustang GT 16 03-28-2012 03:38 PM
Mustang #4 (SOLD) :: 2004 Ford Mustang GT 5 Speed SNK3BTE04 Member Garages 0 03-13-2012 10:41 AM
Replacing vert top WBR0511 1996-2004 Mustang GT 4 03-08-2012 01:47 PM
Vinyl top advice Neds68Stang Classic Mustangs 9 03-07-2012 06:33 PM
Replace a Convertible to a hard top?, MustangGT94 1979-1995 Mustang GT 16 03-03-2012 06:53 PM
12:10 PM
