Suspension - Mustang Evolution
Old 03-18-2012, 01:27 PM   #1
StangRebel's Avatar
Suspension
I am about to fully convert my factory suspension system. Im shopping around to see whats the best prices and what people have used and like the most. Open to any suggestions. Thanks!
StangRebel is offline   Reply With Quote
Old 03-18-2012, 08:59 PM   #2
Blogger
99ford's Avatar
Re: Suspension
Check American Muscle they have good prices and customer reviews.
Old 03-20-2012, 05:58 AM   #3
StangRebel's Avatar
Re: Suspension
Thanks, ill take a look. They seem to have some of the best prices around.
Old 03-20-2012, 07:10 AM   #4
JimC's Avatar
Re: Suspension
Check with CDC (classicdesignconcepts.com) they had a special going with the FRPP shocks, struts, springs, and a rear sway bar.
JimC is offline   Reply With Quote
Old 03-21-2012, 05:49 AM   #5
StangRebel's Avatar
Re: Suspension
Thanks JimC, ill have a look at that sight today and see if anything good turns up
Old 03-21-2012, 09:03 AM   #6
Re: Suspension
it all depends on how "deep" into it you wish to get. If its a daily driver that is different from a autox car or a drag car, depends on which path you wish to go down.
You can do a few minor things to update it and make it handle much better such as
springs (progressive rate)
shocks/struts (valved to match spring rate)
shorter end links (for sway bar in front)
caster/camber plates for alignement needs
full length weld in sub frame connectors for helping body flex
thats a good start.
Old 03-21-2012, 10:33 AM   #7
StangRebel's Avatar
Re: Suspension
Thanks SpectorV. As of right now its a daily driver so ill probably just improve on what the factory system had. Ill let you know how it goes when i figure it out
Old 03-21-2012, 11:37 AM   #8
jamin22786's Avatar
Region: Iowa
Re: Suspension
anybody know if i'd need caster plates or anything with only the FRPP springs?
jamin22786 is offline   Reply With Quote
Old 03-22-2012, 08:04 PM   #9
Mustangguy0202's Avatar
Check out latemodelrestoration.com I've got my suspension kit on order now should be in any day now. I went with the eibach pro system plus, strut tower brace, and CC plates
Mustangguy0202 is offline   Reply With Quote
Old 03-23-2012, 06:08 AM   #10
StangRebel's Avatar
Re: Suspension
Thanks for the info! Let me know how you like it when you get it installed
Old 03-23-2012, 09:42 AM   #11
JimC's Avatar
Re: Suspension
thats a good start.
Actually the S197 is very different from the Fox bodies or the SN95. The sub frame connectors on the S197 aren't needed because we don't get as much flex (even on my convertible) as the prior generation.
Old 03-23-2012, 12:28 PM   #12
Will do... If its in by today I should be done with the install by this weekend
Suspension Poppavoltron 1979-1995 Mustang GT 3 03-12-2012 03:32 PM
what suspension parts to put power to ground?? mhobbs 1996-2004 Mustang GT 8 03-09-2012 04:29 AM
Anyone know about Tein Suspension 1995boss 1979-1995 Mustang GT 8 03-06-2012 09:52 AM
Suspension Upgrades? mchilliard28 Pre-2005 V6 Mustang 4 03-04-2012 03:33 AM
Suspension help Venomouz831 Pre-2005 V6 Mustang 4 03-02-2012 07:04 PM
08:13 AM
