Ignition Systems - Mustang Evolution
Old 03-21-2012, 02:46 PM   #1
08Mustang's Avatar
Ignition Systems
How much horsepower gains can be attained from platinum spark plugs, the accel coil pack, and the spark plug wires on am?
08Mustang is offline   Reply With Quote
Old 03-21-2012, 03:00 PM   #2
angelofrat42's Avatar
Re: Ignition Systems
ive heard very mixed reviews on those. some people swear they get almost 20hp, others say they didnt notice any difference
angelofrat42 is offline   Reply With Quote
Old 03-21-2012, 03:07 PM   #3
08Mustang's Avatar
That's the reason I'm asking
Old 03-21-2012, 03:12 PM   #4
well ive heard more bad things about them than good
Old 03-21-2012, 07:20 PM   #5
jamin22786's Avatar
Region: Iowa
I think it depends on your mileage. Worn out electrical systems can really benefit from upgrading. I put a similar system on my car, couldn't really tell a difference, but I only had 7,000 miles at the time.
jamin22786 is offline   Reply With Quote
Old 03-21-2012, 09:11 PM   #6
JimC's Avatar
You won't get anything more to speak of for the cost. The stock coil pack is pretty good as it is, and the stock plugs are good too. Many of us running forced induction use the stock plugs - cheap, so can be replaced without spending a bundle. I just replaced mine last weekend like I do every spring and it only cost me $12. The old plugs could still be left in because the gaps were only opened up a little on 3 plugs but at the $2 a plug price just as easy to put new ones in rather than re-gap and clean the old ones.
JimC is offline   Reply With Quote
Old 04-26-2012, 11:30 PM   #7
Lorraine's driver
ab_mach1's Avatar
Do you replace your COP's at a certain mileage, or wait until they die? My car has just over 36,000 miles, but was wondering about their age now.
Instagram: @ab_mach1
Old 04-27-2012, 04:33 AM   #8
JimC's Avatar
The 4.0 doesn't use the COP design. We have a separate coil pack. And they will last a long time. with 150,000 miles on my car I swapped coil packs only because (1) I was having an issue and was trying to isolate what was causing it and (2) I had a spare coil pack in the garage that we scavenged off another car when he blew the engine.
It didn't change the issue I was having and the car now has 201,500 on it. So with only 36,000 your coil pack should be fine.
As far as plugs, I swap mine every spring but only because they are cheap ($2 each) and with forced induction I like to check them before each race season starts (and I am somewhere between 24,000 and 30,000 on them at that point). Since I have to pull them to check them might as well toss new ones in since it is only $12 total to swap. Generally the plugs are fine though and I keep them on hand for spares; gaps might open up some but they could still be used.
Old 04-28-2012, 04:00 PM   #9
Lorraine's driver
ab_mach1's Avatar
Thanks for the info
Bad ignition coil? CrimsonGT 1996-2004 Mustang GT 0 02-17-2012 01:39 PM
Fun Ford Weekend and Super Chevy Shows Welcome Aeromotive Fuel Systems as Series Spo FunFordWeekend At the Track 7 02-09-2012 07:02 PM
testing ignition coil Robbie94gt 1979-1995 Mustang GT 2 01-12-2012 11:12 AM
68 mustang ignition? Dexter Classic Mustangs 6 01-08-2012 08:40 PM
07:04 PM
