4.10 gears - Mustang Evolution
Old 03-21-2012, 03:31 PM   #1
angelofrat42's Avatar
4.10 gears
what else do i need if i get 4.10 gears? i have a manual tranny with 95k miles
angelofrat42 is offline   Reply With Quote
Old 03-21-2012, 07:16 PM   #2
jamin22786's Avatar
Region: Iowa
Bearing kit makes it way easier. Not much point to 4.10 without post, so I'd get a t-lock as well.
Just FYI, that's a lot of stress on the little 7.5" rear, I know a lot of tragic stories. Some do fine with it, I'd suggest swapping in an already set up 8.8
jamin22786 is offline   Reply With Quote
Old 03-21-2012, 07:25 PM   #3
wheelman's Avatar
Definitely
wheelman is offline   Reply With Quote
Old 03-21-2012, 09:13 PM   #4
JimC's Avatar
Re: 4.10 gears
By the time you buy the gears, tlok, and pay for installation you will be around what it would cost you for a take off 8.8.
I tried to build the 7.5 with 3.73's, tlok, and the LPW girdle. It cost me more than the 8.8 I finally swapped in after breaking the "built" 7.5 with just a CAI, tune, and pair of drag radials.
JimC is offline   Reply With Quote
Old 03-21-2012, 10:25 PM   #5
jamin22786's Avatar
Region: Iowa
+1
Old 03-22-2012, 12:49 AM   #6
Re: 4.10 gears
how much would a built 8.8 cost with install? ive heard anywhere from 1500 and up which is a lot more than the 170 for the gears plus 250-300 for install... trying to keep this inexpensive
Old 03-22-2012, 06:53 AM   #7
jamin22786's Avatar
Region: Iowa
I said this exact same thing once! Lol
You have to find a junkyard Shelby to make it work.
Old 03-22-2012, 07:40 AM   #8
JimC's Avatar
Re: 4.10 gears
I was able to pick up a new take off 8.8 with 3.55 gears for $450. There isn't a lot of building up to do with the 8.8, it will be plenty strong as is. Finding one with 4.10's will be the challenge because the most you can get from the factory is 3.73.
Angelofrat are you just doing gears, no tlok? Setting up a 4.10 on the 7.5 rear end is a little tricky from what I've been told. Most are going to whine and the smaller rear end has a lot to do with it.
Old 03-22-2012, 11:17 AM   #9
Re: 4.10 gears
i cant find an 8.8 rear end for a decent price anywhere, newtakeoff has one but its for 1000 which is way more than i want to spend
Old 03-22-2012, 11:24 AM   #10
wheelman's Avatar
Id keep looking and save up. Itll be a lot more expensive if you blow up the 7.5. Or go 3.73. Still plenty torquey,
What Grinds Your Gears? deadsp0t The Bar 21642 03-07-2018 10:18 AM
4.10 gear installation cost? akmiller 2011-2014 Mustang GT 25 10-10-2015 06:12 PM
4.10 club MustangGT02 1996-2004 Mustang GT 27 03-24-2012 11:15 AM
3.73 or 4.10? alexak187 1996-2004 Mustang GT 33 03-23-2012 06:37 AM
Gears Mustangpower5.0 2011-2014 Mustang GT 11 03-19-2012 10:13 PM
04:00 AM
