Rear Axle Shaft - Mustang Evolution
Old 04-02-2012, 01:34 PM   #1
Sycopath80's Avatar
Rear Axle Shaft
I bent my driver side rear axle shaft a lil bit. I need to buy a new one, but Ford wants me to pay $490 for just the shaft... I have a salvage yard that can give me the entire assembly for $500... So i need help finding a shaft or if another vehicles will fit it. I also would like to know if the GT shaft for the 8.8 would fit my 7.5 rear end.
Sycopath80 is offline   Reply With Quote
Old 04-02-2012, 02:24 PM   #2
Re: Rear Axle Shaft
I know pre 05 the 7.5 and 8.8 axles could be swapped (keep in mind you want ones with or without ABS based on what you would have) Not sure on 05+
Old 04-02-2012, 02:31 PM   #3
Sycopath80's Avatar
Ahh ok thanks. I hear u can, but i was wanting a definite
Old 04-03-2012, 08:41 PM   #4
JimC's Avatar
Re: Rear Axle Shaft
No you cannot swap an axle shaft from the 8.8 and 7.5. The 8.8 uses a 31 spline axle and differential. The 7.5 uses a 28 spline.
They are not compatible.
Other Ford products use a different mount system from the Mustang 3-link style, so you have to use a rear end from a Mustang for a 2005+ Mustang.
JimC is offline   Reply With Quote
Old 04-04-2012, 03:25 PM   #5
Sycopath80's Avatar
Thank you very much. Im gonna be buying a whole new rear end
GOT REAR ENDED!!!! mcvicar04 1996-2004 Mustang GT 28 04-08-2012 07:37 AM
7.5 rear end Surffer227 Pre-2005 V6 Mustang 43 03-31-2012 09:56 PM
rear seat delete Sprintradc 2011-2014 Mustang GT 20 03-31-2012 05:25 PM
correct offset on front and rear wheels Savage stallion Classic Mustangs 0 03-30-2012 10:48 PM
rear seat delete 351mustanggt 1979-1995 Mustang GT 7 03-30-2012 08:43 PM
» Members Mustangs
Pig
gtcpa
Avengnd
avengnd
Add your Mustang
07:49 PM
