Strange surge - Mustang Evolution
Old 05-04-2012, 03:50 PM   #1
angelofrat42's Avatar
Strange surge
When my windows are all the way up and I'm sitting with the car on not moving, if I pull both buttons up to trigger the automatic close my rpms will drop like 250 and it will vibrate for an instant. Any ideas why it would do that?
angelofrat42 is offline   Reply With Quote
Old 05-04-2012, 06:57 PM   #2
kf4myo's Avatar
Get your battery tested under a load. If your battery is weak it will draw harder on the alt. and draw the engine down. It could even be just a bad cable connection on your battery. A lot of times the connectors will look good and clean on the outside but when you pull them off the battery post they will be black or corroded on the inside. I hope this helps. It's a good place to start.
kf4myo is offline   Reply With Quote
Old 05-04-2012, 09:32 PM   #3
Enorym's Avatar
Def sounds like a battery problem.
Enorym is offline   Reply With Quote
Old 05-05-2012, 08:43 AM   #4
My car has 96k miles and I bought it with 76k over 2 years ago and have yet to change spark plugs or battery
Old 05-05-2012, 10:15 AM   #5
Enorym's Avatar
I haven't changed my battery bought it back in 06 new...but I know it's leaking because of the residue that's building up on the top near the negative terminal. I have 130,000 miles, but I also live in California.
Old 05-05-2012, 04:43 PM   #6
Enorym's Avatar
Now that I said what I said it jinx'ed me. Battery died...damn you! Hahahaha. Time for an optima or deep cycle. it won't even hold enough of a charge to turn the car over. Ps windows went crazy before it died im sure I'll have to do the window button trick after I get the new battery.
Old 05-05-2012, 11:40 PM   #7
Rogue Slider's Avatar
Dang angel I bought my car used 2 weeks ago and it does the same thing. I guess I need to have mine checked just in case
Rogue Slider is offline   Reply With Quote
02:16 PM
