sqeaking in the engine? - Mustang Evolution
Old 05-14-2012, 11:06 PM   #1
zalizar21's Avatar
I was changing the water pump got some radiator fluid on the pulley system mind you this was 2 week ago and ever since then have had a squeaking in the in the engine. Any suggestion on what it might be guys?
zalizar21 is offline   Reply With Quote
Old 05-15-2012, 06:39 PM   #2
08Mustang's Avatar
Well I would say a wet belt but should be dry after two weeks lol...maybe you didn't line up the belt properly?
08Mustang is offline   Reply With Quote
Old 05-17-2012, 06:41 PM   #3
Mr. SoloDolo's Avatar
was it concentrated fluid? If so it has a high oily like substance maybe it got on a pulley or something :-/
Mr. SoloDolo is offline   Reply With Quote
Old 05-17-2012, 06:59 PM   #4
08Mustang's Avatar
Yeah antifreeze will make it squeak for a few cranks if you get it on a pulley
Old 05-18-2012, 06:01 PM   #5
245ciPony's Avatar
I've been having the same problem with my 06 after spilling coolant on the belt. I can't figure out which pulley is squeaking either since it only does it while im driving.
245ciPony is offline   Reply With Quote
Old 05-18-2012, 08:56 PM   #6
08Mustang's Avatar
Just take off the belt and clean em all
Old 05-18-2012, 11:58 PM   #7
gc19662007's Avatar
Also not a bad idea to check the radiator cap. Mine was starting to fail to the point it would barely squirt out and make the belt squeak but not boil over. That drove me nuts for a couple of weeks before it ended up going completely bad.
gc19662007 is offline   Reply With Quote
Old 05-19-2012, 07:16 AM   #8
kf4myo's Avatar
When I had a squeaky noise I bought a can of belt dressing from the auto parts and sprayed the belt. That worked for me.
kf4myo is offline   Reply With Quote
02:12 PM
