05-31-2012, 07:17 AM
#1 | | Registered User
| Spinning tires
I have another problem that has stressed the hell out of me.
I was working on my car, disconnected the battery. Plugged it back up, went out that night... My tires wouldn't spin! Before I unhooked the battery, they'd spin anywhere whenever I did it, but now they won't spin at all. That's super frustrating.
05-31-2012, 08:40 AM
#2 | | Evolution's Finest
I'm not an expert but it sounds like your traction control is engaged. It probably wasn't at first and then you disconnected the battery and connected it so it reset back to normal. That's just my guess.
__________________ |
05-31-2012, 09:08 AM
#3 | | Registered User
| Quote: |
Originally Posted by Rogue Slider I'm not an expert but it sounds like your traction control is engaged. It probably wasn't at first and then you disconnected the battery and connected it so it reset back to normal. That's just my guess. | So what should I do? I've unplugged the battery again and everything else
05-31-2012, 10:48 AM
#4 | | Evolution's Finest
| Re: Spinning tires
You probably did have traction control turned off and then when you took the battery out it went back to the way it was before (on). Put the batter back in and try turning off traction control.
05-31-2012, 06:57 PM
#5 | | Registered User
Just put of curiosity, where is traction control? I have an 07 pony package and never had issue with a burnout but buddy at work has same year, same tranny but can't light them up around a wet corner, uphill in gravel to save his life.
05-31-2012, 07:08 PM
#6 | | Registered User
| Quote: |
Originally Posted by gc19662007 Just put of curiosity, where is traction control? I have an 07 pony package and never had issue with a burnout but buddy at work has same year, same tranny but can't light them up around a wet corner, uphill in gravel to save his life. | The button "tcs" is it. When you push it and it lights up, he should be able to
05-31-2012, 07:20 PM
#7 | | Registered User
Hmmm I don't have that button.
05-31-2012, 07:46 PM
#8 | | Registered User
I dont have that button either but where did you get that head unit...i want it lol
05-31-2012, 07:48 PM
#9 | | Registered User
| Quote: |
Originally Posted by ponypackage07 I dont have that button either but where did you get that head unit...i want it lol | Haha I'm selling it, actually
06-02-2012, 01:58 AM
#10 | | Registered User
Like it!
06-02-2012, 03:05 AM
#11 | | Registered User
The TCS could've been turned off through a tune that was erased when the ECU reset via disconnecting the battery. Meh.
06-02-2012, 01:33 PM
#12 | | Registered User
| Quote: |
Originally Posted by ponypackage07 I dont have that button either but where did you get that head unit...i want it lol | For that year, with a V6, only the Premium Package gives you the TCS button, I believe that's correct. All GTs have them.
06-02-2012, 01:51 PM
#13 | | Registered User
| Quote: |
Originally Posted by sixty4half
For that year, with a V6, only the Premium Package gives you the TCS button, I believe that's correct. All GTs have them. | I have that button and I have the most basic 05 mustang there is no packages installed I'm my car
06-02-2012, 03:22 PM
#14 | | Registered User
| Quote: |
Originally Posted by 05MUSTANG4.0L Like it! | Where can one find your radio unit? I like the touch screen and all
06-02-2012, 08:01 PM
#15 | | Registered User
Traction control was an option for a v6 some have it some don't
06-02-2012, 11:54 PM
#16 | | Registered User
Found that unit on amazon for around 300+ dollars depending the model. Search for pioneer DVD player
06-02-2012, 11:58 PM
#17 | | Evolution's Finest
| Quote: |
Originally Posted by gc19662007 Just put of curiosity, where is traction control? I have an 07 pony package and never had issue with a burnout but buddy at work has same year, same tranny but can't light them up around a wet corner, uphill in gravel to save his life. | In this case, could be he has a different final drive ratio than you do. Example, you might have 3.27 and he may have 2.73.
06-03-2012, 07:12 AM
#18 | | Registered User
| Quote: |
Originally Posted by Azure
In this case, could be he has a different final drive ratio than you do. Example, you might have 3.27 and he may have 2.73. | Possible. I haven't done any mods other than true duals to my car and really haven't looked into exactly what I have in the rear. Just keep it clean, gas it up, change the oil and filters, and keep air in the tires. My money is going to my ground up 66 Mustang Coupe build.
But it still gives me something to give him crap about in good fun.
06-04-2012, 06:10 AM
#19 | | Registered User
| Quote: |
Originally Posted by Giffmastaflex
Where can one find your radio unit? I like the touch screen and all | I just happened to meet someone that was trading in their ford explorer and just had to ask him to sell it to me
06-04-2012, 07:18 AM
#20 | | Registered User
| Re: Spinning tires Quote:
Originally Posted by Azure In this case, could be he has a different final drive ratio than you do. Example, you might have 3.27 and he may have 2.73. | That's posibly true, My car orignally came with 3.31 Gears, which I changed to 4.10 Gears. So that could make a big difference i his car.
07 GT. SCT: CUSTOM TUNED by MUSTANG SPECIALTIES. STEEDA: CARBON FIBER CAI. FRPP: 410 GEARS. MAGNAFLOW: AGGRESSIVE EXHAUST. BBK: LONG TUBE HEADERS & X PIPE. MSD: COIL PAK. CROSS DRILLED ROTORS. STAGGERED 22" WHL 22X8.5F-22X10R. |
