Turbo VS. Supercharger - Mustang Evolution
Old 06-11-2012, 12:04 PM   #1
Barnyard4572's Avatar
I know turbos are cheaper but I'm wondering which one will bring the most power increase, I never thought you would put a turbo on a mustang since its a muscle car but I'm considering it. Anyone know the specs about both?
Barnyard4572 is offline   Reply With Quote
Old 06-11-2012, 12:05 PM   #2
There was already a thread about this
Mady is offline   Reply With Quote
Old 06-11-2012, 04:10 PM   #3
08Mustang's Avatar
And he wasn't a part of it so chill out
08Mustang is offline   Reply With Quote
Old 06-11-2012, 04:18 PM   #4
Timm04's Avatar
+1
Timm04 is offline   Reply With Quote
Old 06-11-2012, 04:41 PM   #5
08Mustang's Avatar
Anyways...both options will put you over 300hp and will require a new 8.8" rear axle and forged lower compression pistons along with some higher strength head studs and some better connecting rods never hurts either. If you're a manual then you'll need a higher strength clutch as well
Old 06-11-2012, 04:47 PM   #6
gc19662007's Avatar
Originally Posted by Timm04
+1
+2
gc19662007 is offline   Reply With Quote
Old 06-11-2012, 08:37 PM   #7
Originally Posted by gc19662007
+2
+3
ponypackage07 is offline   Reply With Quote
Old 06-11-2012, 09:35 PM   #8
Any idea how much that would run me in the end?
---------- Post added at 10:35 PM ---------- Previous post was at 10:35 PM ----------
+2
Old 06-11-2012, 10:48 PM   #9
jamin22786's Avatar
Region: Iowa
+1
jamin22786 is offline   Reply With Quote
Old 06-11-2012, 10:49 PM   #10
FORDuhl6's Avatar
Originally Posted by ponypackage07
+3
+17
FORDuhl6 is offline   Reply With Quote
Old 06-12-2012, 09:53 AM   #11
08Mustang's Avatar
+2
An x-charger intercooled xtreme supercharger is $6400 and the pistons and rods and head studs can be found on supersixmotorsports.com...around $8k probably
Old 06-12-2012, 09:28 PM   #12
JimC's Avatar
Re: Turbo VS. Supercharger
There isn't any need to build the engine - no need for the forged pistons and rods. The 4.0 is already strong. I put 203,000 miles on my car with the Xcharger, and a friend put over 150,000 on his.
Telling people that they "NEED" to build the engine like that is just wrong and not supported by what those of us who have done it have experienced.
There are lots of boosted 4.0's, turbo, procharger, vortech, and Xcharger running with no problems and not built engines.
And to the OP, the turbo isn't a cheaper option. Any forced induction will run you several thousand dollars. The turbo will produce more horsepower, a centri supercharger will be next in horsepower, and the Xcharger produces the least. But the advantage to the Xcharger is the low end torque.
JimC is offline   Reply With Quote
Old 06-12-2012, 09:38 PM   #13
Huh, well thanks guys!
Old 06-23-2012, 10:28 AM   #14
crackhutch's Avatar
You dont NEED to replace the engine internals but i highly recommend you replace the driveshaft...especially if you plan on raising the speed governor.
crackhutch is offline   Reply With Quote
08:01 AM
