Will gt500 fuel injectors fit 06 4.0? - Mustang Evolution
Old 06-21-2012, 11:06 AM   #1
I was told they are a direct replacement wondering if any one else knows, or even where to find 39# atleast. Thanks
dale1371 is offline   Reply With Quote
Old 06-22-2012, 07:20 AM   #2
kickerofdoom's Avatar
They will fit but they are higher flowing so you will get a rich mix of gas and oxygen. It doesn't work look online is your best bet
Old 06-23-2012, 04:15 PM   #3
JimC's Avatar
Re: Will gt500 fuel injectors fit 06 4.0?
Unless you are going forced induction, bigger injectors are a waste for you. The stock injectors are designed to flow properly. You only need bigger injectors if you have forced induction and need the increased flow. The bigger injectors on an otherwise stock engine are a recipe for problems.
And I think that the GT500 injector is a different height - but not sure. So that may cause some clearance problems. I know that my car I just sold with the Xcharger had 39 lb injectors and they were not GT500 injectors (which I believe are bigger than 39 lbs.)
JimC is offline   Reply With Quote
10:11 PM
