engine dies help - Mustang Evolution
Old 06-25-2012, 12:05 AM   #1
jamin22786's Avatar
Region: Iowa
engine dies help
Had to break hard twice tonight for deer. The first time once I was stopped my car didn't want to start going when u gave it has and the engines then died on me. The second time, once i again gave it gas, it felt like I was sick in neutral and not able to shift into first.
I have an '09 V6 auto trans, only 17k miles.
I'm wondering if all my fluids flew forward and screwed up some sensor? Any ideas?
jamin22786 is offline   Reply With Quote
Old 06-25-2012, 12:48 AM   #2
It's not me, it's you.
primer2tone's Avatar
I had a cavalier that would do that. I took it to get checked out and the dealer wanted to sell me a new computer. They said it was a quad driver failure. I never had it fixed I just learned to live with it until I traded it in.
Old 06-25-2012, 02:25 AM   #3
Re: engine dies help
I'd hazard a guess that the sudden stop displaced some debris in your gas tank or fuel filter. Check your fuel pressure and see what it is doing. I don't know the fuel pressure specs for your car, so you will have to Google them up or buy you a Chilton's manual.
Old 06-25-2012, 07:56 AM   #4
Barnyard4572's Avatar
Good luck! You'll have to let us know what the problem is, never heard of that happening. Hopefully it's not An expensive fix.
Barnyard4572 is offline   Reply With Quote
Old 06-25-2012, 08:05 AM   #5
sabrina1265's Avatar
What kind of car do you have
sabrina1265 is offline   Reply With Quote
Old 06-25-2012, 08:10 AM   #6
05MUSTANG4.0L's Avatar
Still under warranty right, 17 k miles
05MUSTANG4.0L is offline   Reply With Quote
Old 06-25-2012, 08:11 AM   #7
What make model etc is it
Old 06-25-2012, 10:52 PM   #8
jamin22786's Avatar
Region: Iowa
I imagine I'm no longer under warranty due to its age. 2009 V6 automatic, 45th anniversary edition.
Old 07-14-2012, 09:19 AM   #9
Enorym's Avatar
Oh you might have set the engine breaker off! Driver side kick panel you will find a button look closely to the left side of the break pedal. In front of your door. There's a small black button press it down. It may or may not fix your problem.
Enorym is offline   Reply With Quote
Old 07-14-2012, 09:30 AM   #10
jamin22786's Avatar
Region: Iowa
I figured out the problem, had a setting wrong on my programmer, I guess the situation must have exasperated the issue
06:01 PM
