Originally Posted by Claypops Does anyone have a Vortech supercharger. I've looked ant turbos and superchargers and Vortech seems to be the best. But I want to get an opinion from someone who actually has one. Pros and cons? |
The pro's:
Yes...and I've installed two. One on my friends 99' cougar which he has had installed since 2001 and one on my 06' mustang which I installed back in 2009.
It's an extremely reliable kit that's the entire reason I went with it. Considering my friend with the cougar that I helped install over 11 going on 12 years ago has had not one episode.
That being said I have 128,000miles on my mustang, I installed it just below 70,000miles meaning I've logged 50,000 miles on it already.
The newer kits for the 4.0 will be an easier install since you don't have to drill a oil line for return oil in the front of your engine. The new kits are designated v3. I have a v2 kit and am happy with it. It's a slightly different supercharger kit.
Ps make sure you buy new plugs "champion rs10lc" they are the coldest plugs I could find that arnt silver and gap them to .030-.035.
So that's the pros.
The cons:
I had to cut the **** out of my fan shroud so the piping would not rub against my fan shroud "attached photo". I only discovered this problem after 10,000miles. Make sure you use Teflon tape on all your fittings so it won't leak. My friend with the cougars leaked a bit where there was no teflon tape.
Keep your engine bay dry. My vortech tensioner pulley went bad at around 40,000miles I live in San Francisco where it's always damp and foggy. And since I live near the ocean things tend to rust when induced to moisture. This only happened because I removed my rubber seal that helps keep rain water out. Which I've recently reinstalled. It was a $50 pulley the bearings were little rusty on the old unit causing the noise.
Conclusion:
In my eyes I couldn't have made a better choice. Especially since I live in
California and laws impede on my freedoms to mod "smog legalities". All of my parts have to have a carb eo# and they do. I don't have to worry about being pulled over for illegal mods and have my car towed like a lot of the Honda and Toyota guys. It produces a lot of power, affordable and most of all the number one thing in my book it's reliable.
