convertible broke - Mustang Evolution
Old 07-01-2012, 02:12 PM   #1
Giffmastaflex's Avatar
convertible broke
So I pulled in my driveway today and was putting the top back up on my car and I heard a small crack sound and thought nothing about it but then when I went to put it back down, the top would not move, any suggestions on what the problem is other than spending 500 bucks
Giffmastaflex is offline   Reply With Quote
Old 07-02-2012, 08:34 PM   #2
Rogue Slider's Avatar
It might be the motor. You still under warranty?
Rogue Slider is offline   Reply With Quote
Old 07-02-2012, 09:18 PM   #3
No its not but the motor runs but the top won't go down, I slowly put the top down by hand and it does go back up with the switch just not down
---------- Post added at 09:18 PM ---------- Previous post was at 09:17 PM ----------
No its not, but I can still hear the motor running, the top won't go down but I did put it down slowly by hand and when I press the button to make it come back up, it works. Could it be I need some sort of fluid in there?
Old 07-02-2012, 11:24 PM   #4
Sorry I'm not an expert I'm just guessing and maybe something might stick. Since you can hit the switch and make it go down something might be wrong with the switch. I know AM sells a one-touch switch but see if you can get a mechanic to look at it and then fix it yourself
Old 08-31-2012, 02:30 AM   #5
Mactracy's Avatar
It might be the hydronic cylinder. My 04 had that problem the bolt that holds it upright snapped and now you have to walk it down and button it up. Price was about $170 for it. You can do the replace your self.
Mactracy is offline   Reply With Quote
04:33 AM
