Removing spoiler - Mustang Evolution
Old 07-03-2012, 02:10 PM   #1
C_Dailey95's Avatar
Removing spoiler
First time poster here, just a quick question. I know it's possible to remove the spoiler, but I would remove it and keep it off. Is there a way to plug the holes or anything to keep them from showing?
C_Dailey95 is offline   Reply With Quote
Old 07-03-2012, 02:41 PM   #2
Blakhwk's Avatar
I remember one of the guys here did it, I hope he will see your post!
Visca Barça
Blakhwk is offline   Reply With Quote
Old 07-03-2012, 08:09 PM   #3
Rogue Slider's Avatar
Ok here goes. Once the spoiler is removed get some I those plastic plugs from your local hardware store. Sand the tops down flush. Then use touch up paint to match your car and use silicone gel to keep them in the holes to make sure it's water tight. Once I find the video I will post it here
Found it
I can't tell by your picture if you have a GT spoiler or the flat spoiler. I had the flat spoiler and replaced mine with a GT spoiler. The flat spoiler is going to be a real pain to get of because they used 2 long strips of the industrial double sided tape. 2 strips about 12 inches long. Make sure you want to remove it because you might crack the spoiler removing it.
My before and after pics
ID:	57523   Click image for larger version
Rogue Slider is offline   Reply With Quote
Old 07-03-2012, 08:17 PM   #4
C_Dailey95's Avatar
Found it
Thank you!
Old 07-03-2012, 08:20 PM   #5
I just added more info to my post above while you were posting
Old 07-03-2012, 11:04 PM   #6
C_Dailey95's Avatar
I just looked at your photos. It is the same spoiler as yours. What the best way to unstick the tape?
Old 07-03-2012, 11:24 PM   #7
It will be better if you have help when you take the 4 screws off it will be stuck on like cement. One person can lift the spoiler while the other can use a sharp knife and I mean very sharp knife to cut the tape that's holding down the spoiler. If you're alone use something to place under the corner of the spoiler after you cut it because if it touches that tape again it will stick down.
Old 07-03-2012, 11:38 PM   #8
C_Dailey95's Avatar
Ok cool. Thanks for the advice! I'll let you know how it goes when I get the chance to actually work on it.
Old 07-03-2012, 11:42 PM   #9
Cool keep me updated
Old 07-04-2012, 10:51 AM   #10
BigRob1127's Avatar
Hey Rogue is the GT spoiler you installed on yours Matte Black? Not sure if it is but looks cool.
BigRob1127 is offline   Reply With Quote
Old 07-04-2012, 01:14 PM   #11
It was silver so I plasti-dipped it
Old 07-04-2012, 08:04 PM   #12
angelofrat42's Avatar
Hey man I did a spoiler delete a couple of months ago. I just went to maaco and paid 300 for them to fill the holes and repaint it. Looks flawless.
angelofrat42 is offline   Reply With Quote
Old 07-04-2012, 08:29 PM   #13
C_Dailey95's Avatar
Damn. That looks really clean. I just can't afford that, I still owe my parents around 300 bucks for my exhausts.
Old 07-04-2012, 09:34 PM   #14
The way in the video is way cheaper
Old 07-05-2012, 09:06 AM   #15
Tip - you can use some rubbing alcohol to eat away at the adhesive on the tape. This should make it a lil easier to pry off and should prevent it from re-adhering if it does slip.
sixty4half is offline   Reply With Quote
Old 07-05-2012, 10:06 AM   #16
The problem with that is the tape covers most of the spoiler so you still have to pry it up without using anything unless you want to pour it all over the trunk so it can get to the tape
Old 07-05-2012, 10:53 AM   #17
05MUSTANG4.0L's Avatar
is there am oreilly by you????
05MUSTANG4.0L is offline   Reply With Quote
Old 07-05-2012, 12:02 PM   #18
C_Dailey95's Avatar
I don't think so. I have a vornhagen though.
Old 07-05-2012, 02:24 PM   #19
They sell u here in houston your original color from your car color code in a spray can bottle with the gloss already in it $22
Old 07-05-2012, 03:17 PM   #20
I understand that. But giving the bottom of the tape a swipe of alcohol with a rag, as you are lifting the spoiler, should prevent it from re- adhering if you drop it.
Old 07-05-2012, 04:48 PM   #21
245ciPony's Avatar
I just sprayed goo gone on mine and let it soak in for an hour. My spoiler pulled right off after I unbolted it.
245ciPony is offline   Reply With Quote
Old 07-05-2012, 10:22 PM   #22
C_Dailey95's Avatar
I plan on working on the spoiler tomorrow. I'll post pictures and let you guys know how it goes. Thanks for all the advice as well!
Old 07-05-2012, 10:59 PM   #23
blackhawk 1's Avatar
Re: Removing spoiler
good luck
blackhawk 1 is offline   Reply With Quote
Old 07-05-2012, 11:20 PM   #24
Post pics when finished
Old 07-05-2012, 11:25 PM   #25
jamin22786's Avatar
Region: Iowa
Best way to get taped on parts off: dental floss. Use a long piece and work it between the spoiler and car.
jamin22786 is offline   Reply With Quote
Old 07-06-2012, 07:48 AM   #26
C_Dailey95's Avatar
I'll try that. Thank you.
Old 07-06-2012, 04:23 PM   #27
C_Dailey95's Avatar
One more quick question before I start working on removing the spoiler. Where can I buy ford touch up paint from?
Old 07-06-2012, 05:12 PM   #28
Blakhwk's Avatar
Ford dealers, autozone, pep boys, advance auto parts, or any other auto parts store!
Visca Barça
Old 07-06-2012, 05:23 PM   #29
C_Dailey95's Avatar
Cool, thank you!
Old 07-06-2012, 06:37 PM   #30
C_Dailey95's Avatar
I got the sides to come loose. I'm have trouble with the very center of the spoiler though. Any ideas? Ive tried the dental floss and it just keeps snapping.
Old 07-06-2012, 06:49 PM   #31
Blakhwk's Avatar
Try the fishing line maybe!
Visca Barça
Old 07-06-2012, 07:36 PM   #32
C_Dailey95's Avatar
I finally got it off. Now I just need to get all the tape off and fill the holes!
Old 07-06-2012, 08:24 PM   #33
You can also try WD-40
Old 07-06-2012, 08:48 PM   #34
C_Dailey95's Avatar
Everything is off, I cant fill the holes yet though because none of them are the same size ad 1 of them isn't even a circle >
Old 07-06-2012, 11:48 PM   #35
That looks great. You can still go to the hardware store and get those plastic fillers and just trim it down to the size for the one that's not a full circle
12:57 AM
