coil pack - Mustang Evolution
Old 08-11-2012, 02:34 PM   #1
goatsoup's Avatar
Region: Maine
coil pack
Ok so i was going to get the screamin demon coil pack but its out of stock on am spend more on the GMS coil for $140. also the gms says increase up to 18hp, is that true? lol. My final option is to get the denon coil pack from a site called gettorq, anyone know how good they are?
goatsoup is offline   Reply With Quote
Old 08-11-2012, 04:01 PM   #2
JimC's Avatar
Re: coil pack
Why do you think you need to change the coil pack? The stock coil pack is fine, and the others don't really do much.
And don't believe the sales hype. A coil pack is not going to give you 18 hp.
JimC is offline   Reply With Quote
Old 08-11-2012, 04:15 PM   #3
goatsoup's Avatar
Region: Maine
Oh really? lol glad i asked i was told i should get new coil pack new plugs and wires
Old 08-11-2012, 04:39 PM   #4
JimC's Avatar
Re: coil pack
I went 170,000 on the stock coil pack with the supercharger on it from 90,000 miles. I swapped to a stock coil pack I had in the garage when it seemed to be acting up (a friend blew up his car on the dyno pushing 25 lbs of boost so we scavenged parts that I might need some day off his 4.0 when he put the V8 in). I sold the car with 203,000 miles on it and the second coil pack - no problems at all.
The plug wires may need replacing. How many miles do you have on yours? They will give out long before the coil pack
Old 08-11-2012, 04:43 PM   #5
goatsoup's Avatar
Region: Maine
Im at 86k right now
Old 08-11-2012, 06:02 PM   #6
JimC's Avatar
Re: coil pack
Not likely any problem with the coil pack then. The wires could be ready for replacement. The plugs are supposed to last 100,000 miles. I swapped them more often, but that was because I was running nitrous on the car for two years and then the supercharger. The plugs were only $2 each (no need for the expensive plugs by the way when you get ready, the stock plugs are fine, even with an engine on forced induction). With the forced induction I wanted to check the plugs each spring, and since I had them out already and they were so cheap it was just as easy to swap in new plugs. But the plugs I pulled with about 30,000 hard miles on them (daily driving and weekend racing) were good enough that I could have gone another 30,000 on them easily.
Old 08-11-2012, 06:18 PM   #7
goatsoup's Avatar
Region: Maine
Ugh i ordered the plugs and wires already lol. Lesson learned. thanks a ton for the information though, definately a big help
Old 08-11-2012, 06:45 PM   #8
dolfin13's Avatar
I bought the sreamin demon ,with street thunder wires and iradium plugs, aftermarket is always better than stock, the coil puts out 40.000 volts, it helps with quicker starts, it helps burn the fuel more efficently, but unless u have a tuner i wouldnt get one, also i noticed that if u have dual exhaust, it helps to take away that tinny sound u get at the higher rpms, im glad i got one, but no ur not gonna get 18 more hp out of it
dolfin13 is offline   Reply With Quote
09:21 PM
