Coolant leak - Mustang Evolution
Old 08-12-2012, 09:29 PM   #1
Claypops's Avatar
Coolant leak
I have a coolant leak and it looks like its coming from the water pump. I have 106k miles on it so I'm hoping it's just normal wear and tear and the water pump gasket needs to be replaced and not the whole pump. Any ideas though?
Claypops is offline   Reply With Quote
Old 08-12-2012, 10:57 PM   #2
Cobrarunnin9s's Avatar
Re: Coolant leak
If it's coming out the weep hole, the water pump is shot.
Cobrarunnin9s is offline   Reply With Quote
Old 08-13-2012, 09:03 PM   #3
Claypops's Avatar
There is no way it could just be the gasket if that's where it's leaking from.
Old 08-14-2012, 04:58 PM   #4
Re: Coolant leak
It could be the gasket, was just stating that fact about the pump. Your just going to have to look and see if you can spot where the leak is coming from.
Old 08-14-2012, 06:55 PM   #5
zalizar21's Avatar
Re: Coolant leak
I had to change out my water pump it only took 45 mins and 60 bucks for a new OEM water pump from autovalue.com
zalizar21 is offline   Reply With Quote
Old 08-14-2012, 07:10 PM   #6
Claypops's Avatar
Ok thanks guys. What about a pump from autozone or oriellys?
Old 08-14-2012, 07:27 PM   #7
Re: Coolant leak
Ya that will work, just make sure you have a dead blow. My pump was kind of fused in it's housing. The o-ring was really attached to the aluminum. A generous tap with a dead low hammer will help without damaging it or the housing.
Old 08-15-2012, 10:33 AM   #8
Barnyard4572's Avatar
If you get a spray bottle full of reall soapy water, you can spray around where you think it leaking. When you start to see bubbles, then that where its at. It works good for hoses so it should work for that.
Barnyard4572 is offline   Reply With Quote
Old 08-16-2012, 08:15 PM   #9
JimC's Avatar
Re: Coolant leak
It may not be the water pump. Take a good look at the plastic thermostat housing. If you got 106,000 miles on it there is a good chance that the housing is split. The split usually happens on the back.
JimC is offline   Reply With Quote
Old 08-16-2012, 09:42 PM   #10
Claypops's Avatar
Oh ya I already had to change that at like 103k. But I will def look again. I've seemed to always have a problem with my coolant since I got the car. Is that normal for mustangs or just the fact I have so many miles?
Old 08-16-2012, 10:11 PM   #11
Blogger
99ford's Avatar
Seems to me that may be an issue. I thought the GT used metal in the housing.
Whoops this is the V6. Yeah I had mine go out at 60k miles. It's common in the ranger after reading on the net.
03:27 AM
