$1600 - Mustang Evolution
Old 08-14-2012, 10:59 PM   #1
Barnyard4572's Avatar
$1600
I just came into some extra money, what can i do (performance wise) to get the most horses an stay within the budget. Its already tuned with a cai.
Barnyard4572 is offline   Reply With Quote
Old 08-14-2012, 11:09 PM   #2
xhgwx's Avatar
Cam/Heads
Super six motor sports.
Gears T-Lok
Suspension
UDPs
Headers
Full exhaust
Some ideas for you.
xhgwx is offline   Reply With Quote
Old 08-14-2012, 11:26 PM   #3
alrefire's Avatar
Re: $1600
with 1600 bucks, upgrade your drivetrain and suspension
3.73 or 4.10 gears with lsd (not the drug)-about 400 with forum discount
upgrade shocks, struts, lowering springs, sway bars
Old 08-15-2012, 08:21 AM   #4
Originally Posted by xhgwx
Cam/Heads
Gears T-Lok
Suspension
UDPs
Headers
Full exhaust
Some ideas for you.
What are UDP's?
Old 08-15-2012, 08:42 AM   #5
It's not me, it's you.
primer2tone's Avatar
Under drive pulley.
Old 08-15-2012, 08:48 AM   #6
deadsp0t's Avatar
Don't waste money on pulleys, almost always way more hassle then they are worth. Befit you dump money into a 7.5" rear end, look into upgrading to an 8.8" rear. The 8.8 will hold whatever you plan to throw at it now and later.
That's unimpressive
Old 08-15-2012, 09:33 AM   #7
I never really understood the gears and ratios and all that. Can someone explain it a little more. And when i look at the pulleys it seems like they are only really meant for gt's.
Old 08-15-2012, 01:37 PM   #8
alrefire's Avatar
Higher gear ratio = faster acceleration, less mpg, lower top speed
Old 08-15-2012, 04:56 PM   #9
xhgwx's Avatar
The city MPG will rise, highway will lower, about the top speed thing, ask cole Johnson he had a 2004 GT I believe and his top speed jumped up when he put 4.10s in by a good bit
Old 08-15-2012, 05:16 PM   #10
Re: $1600
Your top speed goes up (technically) because when you are going that fast all the wind resistance on your car makes it impossible for the motor to turn the gears at a certain speed. Now if you make those gears easier to turn (like 4.10s are) then you will be able to go a higher speed.
Now if you put your car on a dyno and test out the top speed it can go with stock gears vs. higher gears you will reach a higher speed with the stock because there is no resistance on your car.
Old 08-16-2012, 01:29 AM   #11
alrefire's Avatar
Re: $1600
also, if you're tuned with bama, don't get meth injection, nos, cams, turbo/supers, ported heads, lower comp ratios or anything of that sort because bama won't tune your car once you get that kind of stuff
get all of your other upgrades (mostly bolt ons) because they will tune that. better to get all those out of the way so that you don't have to pay 500 (for a dyno tune) every time you get a new upgrade
---------- Post added at 02:29 AM ---------- Previous post was at 02:28 AM ----------
okay, thanks for clearing that up for me!
and nice wrestling shoes
05:44 PM
