8.8 rear end on 09 v6 - Mustang Evolution
Old 08-15-2012, 10:01 PM   #1
Wmcgrattan's Avatar
Im looking to upgrade my rear end before I supercharge my 4.0 what do I need to have to complete the conversion?
Wmcgrattan is offline   Reply With Quote
Old 08-16-2012, 01:46 AM   #2
deadsp0t's Avatar
As long as it comes from a similar year model shouldn't need anything, it would be a good time to add control arms
That's unimpressive
Old 08-16-2012, 08:14 AM   #3
Wmcgrattan's Avatar
Would I need to convert the driveshaft ? An I plan on getting control arms sway bars an coil overs also
Old 08-16-2012, 09:11 AM   #4
deadsp0t's Avatar
With your mods that would be the natural progression IMO.
Maybe someone can chime in but idk about hooking up your parking and rear brakes.
That's unimpressive
Old 08-16-2012, 11:56 AM   #5
Wmcgrattan's Avatar
I know it's a straight forward installation but will the driveshaft hold up to the power that I'll be putting down ?keep in mind I have bbk CIA an throttle body , Mac long tube headers , bbk xpipe , an magnaflow comp. cat back , an its dropped 1inch
Old 08-16-2012, 08:06 PM   #6
JimC's Avatar
Re: 8.8 rear end on 09 v6
You use the same driveshaft and the 8.8 is a direct swap as far as mounting up. If you get a rear end from a 2005- 09 GT you need to swap the pinion flange so your V6 driveshaft will mount.
If the rear end comes from a 2011+ Mustang (not sure about the 2010) then my understanding is that it comes with the correct pinion flange on it already for the 2005-09 V6.
Since it is the same driveshaft it will hold up to anything you have put to it.
JimC is offline   Reply With Quote
09:47 AM
