Emergency Brake - Mustang Evolution
Old 08-17-2012, 03:26 PM   #1
Blakhwk's Avatar
Emergency Brake
When I bought my stang, I had an issue with the emergency brake, the handle won't come up, it's only click once or maybe not even a click, and with this one click the light on the dash will come on but really there is no brake engaged.
Anyone had this issue before or have an idea what it could be the problem!
Thanks
Visca Barça
Blakhwk is offline   Reply With Quote
Old 08-18-2012, 01:22 AM   #2
Rogue Slider's Avatar
I'm just taking a guess here but it sounds like the E brake cord is to tight
Rogue Slider is offline   Reply With Quote
Old 08-18-2012, 12:34 PM   #3
Re: Emergency Brake
Thanks
Does it come up all the way and only click once? Or is it really hard to pull and it barely comes up?
Old 08-18-2012, 11:18 PM   #4
Blakhwk's Avatar
I also thought about that but I don't know how or where to start and look for the cord! Today I tried to remove the plastic part that covering the transmission and the e brake, it wasn't easy and I didn't have the time, I will try next time but I hope I will find something under that cover!
---------- Post added at 12:18 AM ---------- Previous post was at 12:15 AM ----------
It's hard to pull it and clicks barely once.
Another question maybe will lead to something, does the e brake related to the rear brake system? coz my rear brakes and especially the calipers are rusted and needs to be replaced!
Visca Barça
Old 08-18-2012, 11:24 PM   #5
Blogger
99ford's Avatar
There is a TSB out there check out 218291.
---------- Post added at 01:24 AM ---------- Previous post was at 01:21 AM ----------
Google TSB: 218291 or mustang TSB 218291
It may be a good idea to go to Ford and let them fix it. Or a trust worthy mechanic.
Old 08-20-2012, 09:55 PM   #6
Blakhwk's Avatar
Thanks man, I did google it and I got all the TSBs for the car, and I got the one for my e brake.
That was very helpful, appreciate it
Visca Barça
Old 08-22-2012, 08:21 PM   #7
Blogger
99ford's Avatar
No problem! I just remembered it checking something else.
Old 09-11-2012, 08:38 AM   #8
kirpy's Avatar
Re: Emergency Brake
I have the same problem on my 05. I think its due to the lack of use from the previous owner. From what i have found is they like to rust shut if not used. Youll have to replace the whole cable. And i recomend doing it. Because my rotors in the back are really screwed up on mine.
kirpy is offline   Reply With Quote
Old 09-12-2012, 08:29 AM   #9
Blakhwk's Avatar
Not only my rear rotors screwed up, even my calipers are rusted and don't work properly, when i first got it I had I noise in the rear breaks so I thought that's from the old pads, when I tried to replace the pads I realized that the calipers' bolts are stuck and preventing the calipers from moving properly, so even when I replaced the pads I still have this noise coming from the break!
Visca Barça
Old 09-12-2012, 08:33 AM   #10
kirpy's Avatar
Re: Emergency Brake
Same here. Ill prob have to replace them. Im just trying to figure out if i want to do a big brake upgrade.
10:03 PM
